I am protecting a reverse-proxied service with Authelia.
I also realized that some of the URI paths should not be protected and available as-it. To this I created several reverse-proxy
entries for the service, and only one of them should import the Authelia configuration.
import
is however rejected when trying to run the configuration
✔ Container caddy Started 0.6s
caddy | {"level":"info","ts":1691574274.5058055,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy | Error: adapting config using caddyfile: parsing caddyfile tokens for 'reverse_proxy': /etc/docker/authelia/caddy-authelia.conf:10 - Error during parsing: unrecognized response matcher not, import chain: ['/etc/caddy/Caddyfile:72 (import)','/etc/docker/domotique/caddy.caddyfile:8 (import authenticate-with-authelia)']
caddy exited with code 0
v2.7.2 h1:QqThyoyUFAv1B7A2NMeaWlz7xmgKqU49PXBX08A+6xg=
Docker container with image: caddy:2
(main file)
admin 0.0.0.0:2015
email REDACTED
level ERROR
# first import authelia config
import /etc/docker/authelia/caddy-authelia.conf
# import other config files
import /etc/docker/*/Caddyfile
import /etc/docker/*/caddy.caddyfile
(caddy-authelia.conf
https://authelia.swtk.eu {
reverse_proxy authelia:9091 {
trusted_proxies private_ranges
(authenticate-with-authelia) {
@forceAuth {
not remote_ip private_ranges
forward_auth @forceAuth authelia:9091 {
uri /api/verify?rd=https://authelia.swtk.eu/
copy_headers Remote-User Remote-Groups Remote-Name Remote-Email
(the problematic reverse proxy)
https://hass.swtk.eu {
level ERROR
reverse_proxy /api/* 192.168.10.2:8123
reverse_proxy /auth/* 192.168.10.2:8123
reverse_proxy * {
# import authenticate-with-authelia
to 192.168.10.2:8123
The config works when import
is commented out
