WoJ
(WoJ)
1
I need to chain two reverse proxies with the websocket
parameter.
https://example.com -> http://example.com -> 172.1.1.1:9999
The first reverse proxy works great: Opening http://example.com
gets me to the application
The second proxy has problems: I get to the application, but it informs me that there is a problem with the websockets.
Is it in principle possible to chain reverse proxies which also also need to proxify websockets?
I haven’t heard any reason websockets would specifically not work in a proxy chain, but I’ve never tried it myself.
What’s your Caddyfile?
WoJ
(WoJ)
3
These were basic Caddyfiles (they are automatically generated, I am writing them from memory but these were absolutely basic setups)
https://example.com {
proxy / https: {
websockets
and then
proxy / 172.1.1.1:9999 {
websockets
I solved my problem in the meantime by simplifying the setup which allowed me to avoid chaining proxies.
system
(system)
Closed
4
