Caddy V2.1.1
I run Caddy with the Caddyfile in /etc/caddy and enabling systemd service
Caddy is installed on a raspberry pi 4 running raspbian buster. Kernel 4.19.118-v7l+ Systemd version 241
sudo systemctl enable caddy.service
After=network.target
chomsky.ddns.net
reverse_proxy 127.0.0.1:8096
output file /media/ramdisk/acces.log {
roll_size 50MiB
roll_keep 5
roll_keep_for 48h
ipfilter / {
rule allow
database /home/pi/ipfilter/testdata/Geolite.mmdb
country DE
3. The problem Iām having:
I use Caddy as a reverse proxy for my Jellyfin media server.
So I want to block repeat offenders trying to access port 443 and 80 using Fail2ban or only allow IP addresses from a certain country. Problem with fail2ban is that there is no Fail2ban module and I donāt have a clue how what the failregex should be.
Using the above Caddyfile gives me an error. The Caddyfile without the ipfilter part runs good.
[I] [pi@raspberrypi ~ ]$ sudo systemctl status caddy.service
ā caddy.service - Caddy
Loaded: loaded (/lib/systemd/system/caddy.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2020-07-09 09:31:23 CEST; 23s ago
Docs: Welcome ā Caddy Documentation
Process: 6490 ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/Caddyfile (code=exited, status=1/FAILURE)
Main PID: 6490 (code=exited, status=1/FAILURE)
Jul 09 09:31:23 raspberrypi caddy[6490]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Jul 09 09:31:23 raspberrypi caddy[6490]: HOME=/var/lib/caddy
Jul 09 09:31:23 raspberrypi caddy[6490]: LOGNAME=caddy
Jul 09 09:31:23 raspberrypi caddy[6490]: USER=caddy
Jul 09 09:31:23 raspberrypi caddy[6490]: INVOCATION_ID=fc08e61e021441e382590d299acc5886
Jul 09 09:31:23 raspberrypi caddy[6490]: JOURNAL_STREAM=8:39470
Jul 09 09:31:23 raspberrypi caddy[6490]: {ālevelā:āinfoā,ātsā:1594279883.6053421,āmsgā:āusing provided configurationā,āconfig_fileā:"/etc/caddy/Caddyfile",āconfig_adapterā:""}
Jul 09 09:31:23 raspberrypi caddy[6490]: run: adapting config using caddyfile: /etc/caddy/Caddyfile:13: unrecognized directive: ipfilter
Jul 09 09:31:23 raspberrypi systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Jul 09 09:31:23 raspberrypi systemd[1]: caddy.service: Failed with result āexit-codeā.
I tried the above Caddyfile but the directive ipfilter isnāt recognized so Iām guessing this filter is appropriate for Caddy V1? I found that syntax here: ipfilter/README.md at master Ā· pyed/ipfilter Ā· GitHub
I did clone GitHub - pyed/ipfilter: ipfilter is a middleware for Caddy that blocks or allows requests based on the client's IP
Iāve looked through the Caddy V2 documentation all I can find is blocking specific IPās or IP ranges. I did found something related to GeoIP blocking here but I donāt understand how to use it to block all countries but one.
IMPORTANT
So correct me if Iām wrong but do I have to do a custom build of Caddy using xcaddy?
something like: xcaddy build \ --with GitHub - pyed/ipfilter: ipfilter is a middleware for Caddy that blocks or allows requests based on the client's IP
Would the ipfilter plugin work then??
