2.4.3
Installed via PPA and it runs automatically via systemd or manually from caddy start
Ubuntu 20.04
caddy start
https://thedeveloper.club {
tls email@gmail.com
encode zstd gzip
root * /var/www/
php_fastcgi localhost:9000
try_files * /public/index.php
@cachedFiles {
path *.ico *.css *.js *.gif *.jpg *.jpeg *.png *.svg *.woff
header @cachedFiles Cache-Control max-age=5184000
This is based on the question ask at How to assume index.php without sbowing it in the url which worked great, but this would be the follow up:
- When someone visits the site they do not see the index.php in the URL, which is good, but this same index.php is part of Laravel, so when it goes to another folder, the resource urls break. The reason behind this is that they are trying to look for the resource inside /public but they are getting / instead. So for example, the URL the resources get would be this:
Login | HSTS Redirection Community
Which visually is what we want, but the ACTUAL resource is in
Dont know if this makes sense, since it was a bit difficult for me to explain the logic here.
We want to show the resource as this if possible: Login | HSTS Redirection Community
While pulling it correctly from Login | HSTS Redirection Community
which has appended as a prefix the folder /public
Any idea, guidelines?
