“includes in caddyfile” thread from a month ago suggested this solution:
{{include “/includes/docs/head.html”}}
but apparently it needs another module to work. Please suggest how to install/configure it to work.
The command appears in its entirety as text in the webpage.
Looked at Modules - Caddy Documentation but it didn’t indicate how I should go forward to include the module in Caddy. Thank you.
Please elaborate. What’s your full config at that point? What’s in your logs? How did you test it? What behaviour did you see exactly when it “didn’t work”?
I apologize. I tried my previous configuration and can’t get it to fail. Sorry for the inconvenience. Will report if I can reproduce. Happy it works, now.
