How to add custom DNS resolver to Caddyfile
I’ve read here but could not figure out where to add a custom DNS resolver to my Caddyfile.
I want to use udp://8.8.8.8 as DNS resolver.
My Caddyfile:
  order forward_proxy before file_server
:443, example.com {
  tls me@example.com
  forward_proxy {
    basic_auth user pass
    hide_ip
    hide_via
    probe_resistance
  file_server {
    root /var/www/html
As far as I know isn’t this possible for global caddy instance but for the reverse_proxy as it is in the linked topic you mentioned.
Which module have forward_proxy directive as I can’t find it in the documentation Caddyfile Directives — Caddy Documentation . There is only mentioned the forward_auth (Caddyfile directive) — Caddy Documentation which is a opinionated wrapper over a reverse proxy as you can see here forward_auth (Caddyfile directive) — Caddy Documentation
The only way I see is to set the resolver in the system settings or add that feature to caddy :wink:
Yeah, this is a feature request for the forward_proxy plugin. Open an issue on the github repo for that plugin.
With forward_proxy you mean this one GitHub - caddyserver/forwardproxy: Forward proxy plugin for the Caddy web server ?
