I use docker container with caddy from abiosoft.
I read README, search this forum, but not found how to activate several plugins for this container. For example, I want to activate ipfilter plugin & git plugin.
This is my Dockerfile
FROM abiosoft/caddy
RUN mkdir -p /root/.caddy/
RUN mkdir -p /root/gocode/callrecords-service/logs
COPY ./Caddyfile /etc/
I believe you’ll need to build your own version based off his Dockerfile. You can pretty much copy his Dockerfile and replace the ARGS instruction as needed, e.g. ARG plugins=http.git,http.ipfilter
