How to access metrics from another host?
Ubuntu 20.04
Docker 19.03.1
docker-compose up -d caddy2
version: '3.7'
  caddy2:
    image: gotson/caddy-cloudflare:latest
    container_name: caddy2
      - ~/opt/appdata/caddy2/Caddyfile:/etc/caddy/Caddyfile
      - ~/opt/appdata/caddy2/data:/data
      - ~/opt/appdata/caddy2/config:/config
      # - ~/opt/appdata/caddy2/glype:/srv
      - 2019:2019
      - 80:80
      - 443:443
      - CLOUDFLARE_API_TOKEN=${CLOUDFLARE_API_TOKEN}
http://0.0.0.0:2018 {
  metrics
I am trying to access the Prometheus metrics from outside the container, but can’t.
Without the added metrics block in my Caddyfile, i tried this without success:
curl localhost:2019/metrics
curl: (56) Recv failure: Connection reset by peer
I try to exposed the metrics as its own domain, listening to 0.0.0.0:2018, but that returns nothing:
curl localhost:2018
curl localhost:2018/metrics
nothing relevant even with debug
OK, i’ve found how to listen to all interfaces instead of just localhost for the admin API.
I added this global config to my Caddyfile:
  admin 0.0.0.0:2019
Hmm, try with this:
:2018 {
  metrics
The difference is that Caddy seems to make a host matcher for 0.0.0.0 otherwise. Seems incorrect. Omitting that won’t use a host matcher but will listen on all interfaces. Seems like a bug. Looking into it.
You can see what I mean by adapting your Caddyfile with caddy adapt --pretty --config /path/to/Caddyfile
