):v2.4.5 h1:P1mRs6V2cMcagSPn+NWpD+OEYUYLIf6ecOa48cFGeUg=
Ubuntu 20.4b. Command:
Paste command here.
``` sudo systemctl start caddy-api
#### c. Service/unit/compose file:
<!-- If using Docker/systemd/Kubernetes/make etc. -->
#### d. My complete Caddyfile or JSON config:JSON
Paste config here, replacing this text.
Use caddy fmt
to make it readable.
LEAVE DOMAIN NAMES INTACT.
### 3. The problem I'm having:
<!-- What are you trying to do, and what isn't working? Please describe the issue thoroughly enough so that anyone can reproduce the exact behavior you're seeing. Be as specific as possible. DO NOT USE WEB BROWSERS; use "curl -v" instead. -->i checked my security group then checked the load balancers target group
### 4. Error messages and/or full log output:
<!-- Please **DO NOT REDACT** any information except credentials. Leave domain names intact! -->
<!-- Please **DO NOT POST TRUNCATED LOG LINES** as systemd is notorious for this. -->
<!-- Please **DO NOT USE WEB BROWSERS.** Use curl -v instead. -->
<!-- Please **DO ENABLE DEBUG MODE FIRST** by adding "debug" to the global options of your Caddyfile. -->
### 5. What I already tried:
<!-- Show us what effort you've put in to solving the problem. Be specific -- people are volunteering their time to help you! Low effort posts are not likely to get good answers! -->
### 6. Links to relevant resources:
