How secure a redirect for only on reverse proxy site
I have a site that need to secure or block the reverse proxy only part of
https://remote.access.site - allow all access
https://remote.access.site/web - admin site to protect
The issue is that the two URLS are two different ports.
I want to protect the admin site.
From what I can see there is no way to use a matcher or basic auth for just one reverse proxy site under a domain. It seems to be all or None
Caddy is working normally with everything else. The only issue is the need to lock down that admin site. I think I need to pipe this caddy into another caddy instance. so I can lock that site one down . Thx for your input
N/A
3. Caddy version: 2.7.6
I used Docker to create my caddy service
Docker
sudo docker run -d \
-p 443:443 \
-p 80:80 \
-v /etc/caddy/data:/data \
-v /etc/caddy/Caddyfile:/etc/caddy/Caddyfile \
--restart unless-stopped \
--name caddydec2023 \
caddydec2023
Dockerfile
FROM caddy:2.7.6-builder-alpine AS builder
RUN xcaddy build \
     --with github.com/greenpau/caddy-security
FROM caddy:2.7.6-alpine
https://remote.access.site {
	reverse_proxy /web* https://172.16.15.15:9444 { #admin site that needs to be protected
			tls_insecure_skip_verify
    reverse_proxy 172.16.15.15:4444 #allow remote unprotected access
You can wrap whole segments in route or handle with the reverse_proxy inside them. For example,
     handle /web* {
        basicauth {
            <user> <hashed_pass>
What handle does is enforce mutually-exclusive routing to ensure only one of the 2 handler chains is executed, not both, and to enable conditional chain of handlers as in your case.
wow I works!
thanks so much! you saved me a bunch of time!
