I have a domain, and already got 5 subdomain ssl certificates, and now I can’t get one more certificate, how can I fix this?
Thank you so much.
Thank you so much.
Some customers have many thousands. There’s no real limit. But you are limited by the rate limits of the ACME CAs (Let’s Encrypt and ZeroSSL are the default providers as of v2.3).
Please fill out the help thread template if you need help. We have no way of knowing why you might have run into trouble without the information requested in the template.
I see, the following is my caddy info
caddy version
):v2.1.1 h1:
Debian 9
sudo service caddy start
one.domain.com {
tls hb@domain.com
root * /home/hb/one
two.domain.com {
tls hb@domain.com
root * /home/hb/two
three.domain.com {
tls hb@domain.com
root * /home/hb/three
some subdomains can’t get ssl certification, and can’t be visited, e.g. three.domain.com
But if I change to another domain, e.g.
one.domain.com {
tls hb@domain.com
root * /home/hb/one
two.domain.com {
tls hb@domain.com
root * /home/hb/two
anotherdomain.com {
tls hb@domain.com
Everything works well.
Or if I don’t use ssl
one.domain.com {
tls hb@domain.com
root * /home/hb/one
two.domain.com {
tls hb@domain.com
root * /home/hb/two
http://three.domain.com {
tls hb@domain.com
Also works well.
Where are your logs? Please upgrade to the latest version of Caddy (v2.3 was just released).
Let me update to v2.3 first, I will keep in touch. Thank you.
Upgrade to v2.3, this issue is fixed. Thank you.
