Its not clear from the docs how remote_ip
works in conjunction with ACME-autorenewals ?
Does Caddy allow the traffic through to /.well-known
or is there some config wizardry required to make it work ?
The remote_ip
matcher, like any matcher, applies only to your HTTP handler middleware (directives) that you configure.
ACME challenges are solved out-of-band of your configured handlers and matchers. In other words, you can’t break them. (Well, you can but only by misconfiguring your network or something.)
