v2.4.6.
Docker.
BASIC_AUTH_PASSWORD_HASHED=$(caddy hash-password --plaintext $BASIC_AUTH_PASSWORD) caddy run --config /etc/caddy/Caddyfile.json
ARG CADDY_VERSION=2.4.6
FROM caddy:${CADDY_VERSION}-builder-alpine AS builder
ARG ROUTE53_VERSION=v1.1.2
ARG TLSREDIS_VERSION=v0.2.7
RUN xcaddy build \
--with github.com/caddy-dns/route53@${ROUTE53_VERSION} \
--with github.com/gamalan/caddy-tlsredis@${TLSREDIS_VERSION}
FROM caddy:${CADDY_VERSION}-alpine
ENV XDG_DATA_HOME=/data \
XDG_CONFIG_HOME=/config
COPY static/root /
CMD ["scaddy"]
"admin": {
"listen": ":2099",
"config": {
"load_interval": "60s",
"load": {
"module": "http",
"timeout": "10s",
"url": "http://localhost:5000/caddy-config"
"apps": {
"http": {
"servers": {
"local": {
"listen": [":8080"]
The configuration is never loaded again, after the initial load. I thought it would attempt to load configuration every 60s (based on the config).
{“level”:“info”,“ts”:1637042240.4107828,“msg”:“dynamically-loaded config applied successfully”}
{“level”:“info”,“ts”:1637042228.738454,“msg”:“applying dynamically-loaded config”,“loader_module”:“http”,“pull_interval”:60000000000}
