I am using the Caddy official docker container and this is my very first time using Docker. I setup Portainer to give myself something graphical to assist in administration, but I am still very wet behind the ears when it comes to Docker.
The “How to use this image” section of the page for the image states “This image provides for two mount-points for volumes: /data
and /config
” but I don’t know that I need to do on the host to provide that. I tried to read on Bind Mounts or Volumes, or how to setup either. If they are Bind Mounts, do I simply create those two directories at the root of my host system’s filesystem?
I am not new to Caddy itself, but I have literally never used Docker before, and this is my first container. If I can get some help with this basic item, I can probably move on from here on my own. I just need to get a little push for momentum.
Thank you.
There is nothing to show here
Installed in Docker via Portainer on Debian 12. Everything new as of Yesterday afternoon, when I started from scratch.
Portainer starts it for me, not sure how to answer.
Have not created this yet. I need to know how to mount the two folders first.
