1. Output of caddy version
With caddy start
macOS via homebrew
caddy start
foobar.dev {
reverse_proxy localhost:1337
*.foobar.dev {
I need to do local development testing Google OAuth. This requires that:
- The local server is accessible via a a hostname that “must end with a public top-level domain (such as .com or .org)”. These restrictions imposed by Google OAuth “Authorized JavaScript origins”.
- The browser (Chrome) accepts a certificate for HTTPS.
I am using foobar.dev
as that public hostname. I am using dnsmasq to point this at 127.0.0.1.
I now need a cert for foobar.dev
, just like the self-signed certs that Caddy generates for foobar.localhost
. However, when I run Caddy with this config, I get the error below.
Caddy by default seems to have the policy: “if a public domain name, request from LetsEncrypt; otherwise self-sign”. This policy doesn’t work for me - I need a self-signed cert for foobar.dev
, since I don’t own it. So - what’s the magic config to tell Caddy to just self-sign instead of requesting from LE?
2022/11/20 01:08:18.810 INFO tls.obtain lock acquired {"identifier": "foobar.dev"}
2022/11/20 01:08:18.810 INFO tls.obtain obtaining certificate {"identifier": "foobar.dev"}
2022/11/20 01:08:18.812 INFO http waiting on internal rate limiter {"identifiers": ["foobar.dev"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2022/11/20 01:08:18.812 INFO http done waiting on internal rate limiter {"identifiers": ["foobar.dev"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2022/11/20 01:08:18.829 INFO tls.obtain lock acquired {"identifier": "*.foobar.dev"}
2022/11/20 01:08:18.829 INFO tls.obtain obtaining certificate {"identifier": "*.foobar.dev"}
2022/11/20 01:08:18.830 INFO http waiting on internal rate limiter {"identifiers": ["*.foobar.dev"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2022/11/20 01:08:18.830 INFO http done waiting on internal rate limiter {"identifiers": ["*.foobar.dev"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2022/11/20 01:08:19.993 INFO http.acme_client trying to solve challenge {"identifier": "foobar.dev", "challenge_type": "http-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2022/11/20 01:08:20.087 ERROR tls.obtain could not get certificate from issuer {"identifier": "*.foobar.dev", "issuer": "acme-v02.api.letsencrypt.org-directory", "error": "[*.foobar.dev] solving challenges: *.foobar.dev: no solvers available for remaining challenges (configured=[http-01 tls-alpn-01] offered=[dns-01] remaining=[dns-01]) (order=https://acme-v02.api.letsencrypt.org/acme/order/832393997/145685255337) (ca=https://acme-v02.api.letsencrypt.org/directory)"}
2022/11/20 01:08:20.088 INFO http waiting on internal rate limiter {"identifiers": ["*.foobar.dev"], "ca": "https://acme.zerossl.com/v2/DV90", "account": "caddy@zerossl.com"}
2022/11/20 01:08:20.088 INFO http done waiting on internal rate limiter {"identifiers": ["*.foobar.dev"], "ca": "https://acme.zerossl.com/v2/DV90", "account": "caddy@zerossl.com"}
2022/11/20 01:08:21.347 ERROR http.acme_client challenge failed {"identifier": "foobar.dev", "challenge_type": "http-01", "problem": {"type": "urn:ietf:params:acme:error:unauthorized", "title": "", "detail": "2001:4860:4802:36::15: Invalid response from https://www.foobar.dev/.well-known/acme-challenge/N_yZQq65WOTYQ6C1_bIdmkibi2hc9OO-3AJPQok8PA0: 403", "instance": "", "subproblems": []}}
2022/11/20 01:08:21.347 ERROR http.acme_client validating authorization {"identifier": "foobar.dev", "problem": {"type": "urn:ietf:params:acme:error:unauthorized", "title": "", "detail": "2001:4860:4802:36::15: Invalid response from https://www.foobar.dev/.well-known/acme-challenge/N_yZQq65WOTYQ6C1_bIdmkibi2hc9OO-3AJPQok8PA0: 403", "instance": "", "subproblems": []}, "order": "https://acme-v02.api.letsencrypt.org/acme/order/832393997/145685255617", "attempt": 1, "max_attempts": 3}
2022/11/20 01:08:22.712 INFO http.acme_client trying to solve challenge {"identifier": "foobar.dev", "challenge_type": "tls-alpn-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2022/11/20 01:08:23.265 ERROR tls.obtain could not get certificate from issuer {"identifier": "*.foobar.dev", "issuer": "acme.zerossl.com-v2-DV90", "error": "[*.foobar.dev] solving challenges: *.foobar.dev: no solvers available for remaining challenges (configured=[http-01 tls-alpn-01] offered=[dns-01] remaining=[dns-01]) (order=https://acme.zerossl.com/v2/DV90/order/xnoGq4DtNzKSvX_zZu15SA) (ca=https://acme.zerossl.com/v2/DV90)"}
2022/11/20 01:08:23.265 ERROR tls.obtain will retry {"error": "[*.foobar.dev] Obtain: [*.foobar.dev] solving challenges: *.foobar.dev: no solvers available for remaining challenges (configured=[http-01 tls-alpn-01] offered=[dns-01] remaining=[dns-01]) (order=https://acme.zerossl.com/v2/DV90/order/xnoGq4DtNzKSvX_zZu15SA) (ca=https://acme.zerossl.com/v2/DV90)", "attempt": 1, "retrying_in": 60, "elapsed": 4.436450984, "max_duration": 2592000}
2022/11/20 01:08:23.266 ERROR http.acme_client challenge failed {"identifier": "foobar.dev", "challenge_type": "tls-alpn-01", "problem": {"type": "urn:ietf:params:acme:error:unauthorized", "title": "", "detail": "Incorrect validation certificate for tls-alpn-01 challenge. Requested foobar.dev from [2001:4860:4802:38::15]:443. Received certificate which is not self-signed.", "instance": "", "subproblems": []}}
2022/11/20 01:08:23.266 ERROR http.acme_client validating authorization {"identifier": "foobar.dev", "problem": {"type": "urn:ietf:params:acme:error:unauthorized", "title": "", "detail": "Incorrect validation certificate for tls-alpn-01 challenge. Requested foobar.dev from [2001:4860:4802:38::15]:443. Received certificate which is not self-signed.", "instance": "", "subproblems": []}, "order": "https://acme-v02.api.letsencrypt.org/acme/order/832393997/145685265237", "attempt": 2, "max_attempts": 3}
2022/11/20 01:08:23.266 ERROR tls.obtain could not get certificate from issuer {"identifier": "foobar.dev", "issuer": "acme-v02.api.letsencrypt.org-directory", "error": "HTTP 403 urn:ietf:params:acme:error:unauthorized - Incorrect validation certificate for tls-alpn-01 challenge. Requested foobar.dev from [2001:4860:4802:38::15]:443. Received certificate which is not self-signed."}
2022/11/20 01:08:23.266 INFO http waiting on internal rate limiter {"identifiers": ["foobar.dev"], "ca": "https://acme.zerossl.com/v2/DV90", "account": "caddy@zerossl.com"}
2022/11/20 01:08:23.266 INFO http done waiting on internal rate limiter {"identifiers": ["foobar.dev"], "ca": "https://acme.zerossl.com/v2/DV90", "account": "caddy@zerossl.com"}
2022/11/20 01:08:26.144 INFO http.acme_client trying to solve challenge {"identifier": "foobar.dev", "challenge_type": "http-01", "ca": "https://acme.zerossl.com/v2/DV90"}
Google; trawling documentation
