How can I use Docker secrets with Caddy containers?
~$ caddy version
I am currently running it in a docker container. I am using my own Dockerfile and building it with xcaddy because I am using various modules to get DNS and security.
The ultimate goal is to run caddy as a reverse-proxy and authentication portal for all my docker services. I am using this mostly as a learning experience, because I think there are less elaborate ways to play DND tabletop with friends, but I like over-complicating things I guess.
FROM arm64v8/caddy:builder-alpine AS builder
RUN xcaddy build \
    --with github.com/greenpau/caddy-security \
    --with github.com/greenpau/caddy-trace \
    --with github.com/caddy-dns/googleclouddns
FROM arm64v8/caddy:alpine
OS: Ubuntu 20.04.4 LTS aarch64
Host: KVM Virtual Machine virt-4.2
Kernel: 5.11.0-1028-oracle
Uptime: 2 days, 20 hours, 50 mins
Packages: 795 (dpkg), 6 (snap)
Shell: bash 5.0.17
Resolution: 1024x768
Terminal: node
CPU: (4)
GPU: 00:01.0 Red Hat, Inc. Virtio GPU
Memory: 712MiB / 23996MiB
(I am runnning this on Oracle Cloud Infrastructure)
~$ docker compose -f ./caddy-test.yml up -d
Disclaimer: I know that Docker secrets can only be used in Swarm, so that means no environment variables like the PWD I used. This is the one I’ve been using just to see if __FILE works at all.
Docker compose file I’m using for testing purposes:
version: "3.7"
#INTERNET CONNECTIONS==============================================================================================================================================================
  caddy-test:
    driver: bridge
    external: true
    image: oracleserver/caddy:local
    build:
      context: ./caddy
      dockerfile: Dockerfile
      - ${PWD}/caddy/Caddyfile:/etc/caddy/Caddyfile
      - ${PWD}/caddy/site:/srv
      - caddy_data:/data
      - caddy_config:/config
      - caddy-test
      - GITHUB_CLIENT_ID_FILE=${PWD}/secret/github_client_secret #Do environment secrets need their file extensions?
      - GITHUB_CLIENT_SECRET_FILE=${PWD}/secrets/github_client_secret
      - GCP_CREDENTIALS=${PWD}/secrets/credentials.json #What about for a file that needs to explicitly be json in order to be read? Will encrypting it in Docker swarm secrets make it unreadable?
    extra_hosts:
      - "host.docker.internal:host-gateway"
#SERVICES===============================================================================================================================================================================
  dashy: #FRONT PAGE
    image: lissy93/dashy
    container_name: dashy
      - ${PWD}/services/dashy/config/conf.yml:/app/public/conf.yml
      - NODE_ENV=production
    healthcheck:
      test: [ 'CMD', 'node', '/app/services/healthcheck' ]
      interval: 1m30s
      timeout: 10s
      retries: 3
      start_period: 40s
      - caddy-test
    depends_on:
      - caddy
#STORAGE=================================================================================================================================================================================
  caddy_data:
  caddy_config:
Caddyfile
    order authenticate before respond
    order authorize before basicauth
    security {
        authentication portal myportal {
            crypto default token lifetime 3600
            backend github {env.GITHUB_CLIENT_ID} {env.GITHUB_CLIENT_SECRET}
            cookie domain example.com
            ui {
                links {
                    "My Website" https://example.com:443/ icon "las la-star"
                    "My Identity" "/whoami" icon "las la-user"
                password_recovery_enabled no
            transform user {
                match origin local
                action add role authp/user
                ui link "Portal Settings" /settings icon "las la-cog"
            transform user {
                match realm github
                match sub github.com/oracleserver
        authorization policy users_policy {
            set auth url https://auth.example.com:443/
            allow roles authp/admin authp/user
            acl rule {
                comment allow users
                match role authp/user
                allow stop log info
            acl rule {
                comment default deny
                match any
                deny log warn
        authorization policy admins_policy {
            acl rule {
                comment allow users
                allow stop log info
            acl rule {
                match any
                deny log warn
(dns_config) {
        dns googleclouddns {
            gcp_project {env.GCP_PROJECT}
            gcp_application_default {env.GCP_CREDENTIALS}
auth.example.com {
    import dns_config
    authenticate with myportal
    root * /usr/share/caddy
example.com {
    import dns_config
    authorize with users_policy
    reverse_proxy dashy:80
I am using environment variables to configure Github in the caddy module Github Security.
For example:
    security {
But I also wanted to use Docker Secrets. When I append “FILE” to the environment variables, they don’t read the file, they read the path of the secret file.
Theoretically, GITHUB_CLIENT_ID_FILE should be “LV99999999”, but GITHUB_CLIENT_ID_FILE will read as “/var/run/secrets/github_client_id” instead, right?
According to this source, I can create an entrypoint script to configure the ability to read from FILE myself? I look at the entrypoint script of something like Nextcloud, and that seems to be the case, but I guess I wanted to ask you guys and make sure if I’m on the right track, or if thats already possible and I didn’t do it right. Or maybe its not worth the effort of using docker secrets in the first place?
Note: This isn’t unique to caddy-security, mind you. Its not part of the caddy base docker I think, because I have the same issue with other Caddy modules, like google DNS.
4. What I already tried:
I tried just doing a straight copy and paste form the source I listed below just to see what I would get and where to go from there.
RUN xcaddy build \
COPY docker-entrypoint.sh /docker-entrypoint.sh
RUN chmod a+x /docker-entrypoint.sh
ENTRYPOINT [ "/docker-entrypoint.sh" ]
# docker-entrypoint.sh
#!/bin/bash
set -e
# usage: file_env VAR [DEFAULT]
#    ie: file_env 'XYZ_DB_PASSWORD' 'example'
# (will allow for "$XYZ_DB_PASSWORD_FILE" to fill in the value of
#  "$XYZ_DB_PASSWORD" from a file, especially for Docker's secrets feature)
file_env() {
    local var="$1"
    local fileVar="${var}_FILE"
    local def="${2:-}"
    if [ "${!var:-}" ] && [ "${!fileVar:-}" ]; then
        echo >&2 "error: both $var and $fileVar are set (but are exclusive)"
        exit 1
    fi
    local val="$def"
    if [ "${!var:-}" ]; then
        val="${!var}"
    elif [ "${!fileVar:-}" ]; then
        val="$(< "${!fileVar}")"
    fi
    export "$var"="$val"
    unset "$fileVar"
exec "$@"
The error I got was this:
standard_init_linux.go:228: exec user process caused: exec format error
Github links to Caddy modules I’m using:
References:
6. Ultimate questions:
  1. Is trying to write an entry-point script the right approach? Do I even need docker-secrets? I am trying to implement “best practices” so I can learn them properly.
  2. I am not trying to run caddy as a runnable container so would adding a new entrypoint make it unusuable as a service? (Sidenote: I do however wish I knew how to do that to format Caddyfiles on the host terminal without installing caddy, but that’s maybe a different topic.)
  3. Does the docker version of Caddy already have an entrypoint script I can edit?
  4. Do the exec format errors occur because I have to somehow make an entrypoint specific for ARM64? Or am I doing something else wrong?
  5. Is it a good idea to use docker swarm to encrypt the credentials json used for google dns?
  6. Does Caddy already have an entrypoint script for Docker and I’m just not seeing it?
/cc @greenpau
I do welcome his input, however this applies to all Caddy modules, doesn’t it?
I can’t really speak to Docker Swarm, because I don’t use it, but Caddy has two styles of environment variables.
  • In the Caddyfile, there’s the {$ENV} style, which is read at config adapt time (i.e. right at the start when Caddy adapts your Caddyfile to JSON before running it). This style gets turned into regular text tokens that the Caddyfile will parse as if that text appeared in the Caddyfile directly. Caddyfile Concepts — Caddy Documentation
  • In any config adapter (including Caddyfile), the {env.ENV} style is a placeholder which gets replaced at runtime, and can only be used in config locations where the underlying module actually runs the replacer. This depends on the module, because they must have actually written the code to do this.
I see, so allow me to see if if I understand this correctly:
Even if I were to use a docker-entrypoint script that could somehow input docker secrets into environment variables, if the modules of a Caddy configuration don’t have a “replacer” built into it, it wouldn’t work, because env.ENV variables are only placed at runtime…? Sorry, I’m a little confused, as you can tell.
That’s right, {env.ENV} style many not work everywhere in the config, but {$ENV} style will work everywhere in the Caddyfile.
As long as the environment variable is actually defined before running Caddy, of course.
