How can I share cookies between two subdomain using caddy file
Hi, i want share cookies between all the subdomains of localhost. The cookie is basically generated on localhost:3000/api/set . But it’s is not shared with all the subdmains like home.localhost or learn.localhost. What’s wrong with my configuration.
     admin :2020
     local_certs
home.localhost {
    # Serve the main site
    reverse_proxy 127.0.0.1:3000
learn.localhost {
    reverse_proxy localhost:4000
Howdy @AR_Dhrubo, welcome to the Caddy community.
This isn’t really related to Caddy itself, but rather between the upstream app and the browser. It has to do with the way the server sets the cookies.
I found an answer which might help explain things a little:
