I have a Caddyfile with ~10 subdomains that typically have three directives:
example.com {
forward_auth authelia:9091 {
uri ...
copy_headers ...
reverse_proxy http://homepage:3000
resolvers 1.1.1.1
dns cloudflare TOKEN_HERE
whoami.example.com {
uri ...
copy_headers ...
reverse_proxy http://whoami:80
resolvers 1.1.1.1
# Same thing over and over again with reverse proxy being different
I want to make it a bit more manageable by making some common directives and using them when defining my domains. Basically I want to be able to do something like this:
example.com {
forward_authelia
tls_cloudflare
forward_authelia
tls_cloudflare
Is this something that is possible to do with Caddyfile (maybe not the way I have written but something similar)? If yes, how? If no, can someone suggest me a config adapter that can handle this while having a syntax similar to Caddyfile (I really like Caddyfile syntax)?
No error message
v2.7.6
Setup a docker compose file and ran it inside podman.
Caddy is running in Podman
podman compose up -d
