Distributor ID: Debian
Description: Debian GNU/Linux 10 (buster)
Release: 10
Codename: buster
Using systemd to start it with this command
After=network.target
I admit I redacted some stuff here, mainly my other domains, as I think its not very necessary for this kind of problem
default_sni "philmacfly.eu"
email "letsencrypt@philmacfly.eu"
(logging) {
output file /var/lib/caddy/log/{host}/access.log
(www_redirect) {
redir https://www.{host}{uri}
(compression) {
encode zstd gzip
(phpfpm) {
php_fastcgi unix//var/run/php/php7.3-fpm.sock
(default_root) {
import compression
root * /var/lib/caddy/www/{host}
(file_browser) {
import compression
file_server browse
(default_root_php) {
import default_root
import phpfpm
(pretix_proxy) {
reverse_proxy http://localhost:8345
bia.philmacfly.eu {
import default_root_php
I’m trying to host EQDKP, which is a DKP and Gaming CMS. During installation it tells me that the “PathInfo-Support” is not enabled. A Short search on google lead me to this forum post: [1] which hinted towards this wiki article of them: [2]
Problem now is that it tells me some nginx commands and settings and I have no clue of nginx or how to translate it into caddy.
Instead of using the php_fastcgi “shortcut” I tried to use the Expanded form but instead of using the split like it is using the regex they suply for ngnix
[1]https://forum.eqdkp-plus.eu/thread/3358-installation-requirements-nginx/
[2]https://eqdkp-plus.eu/wiki/Nginx#FastCGI-Params
