Homeassistant resolves perfectly in web browser, but does not resolve on the companion app. I receive a “Starscream.HTTPUpgradeError 0”. From searching this appears to be an issue due to websockets, but from what I saw, caddy should not need special config for websockets (is this correct?)
The operation couldn’t be completed. (Starscream.HTTPUpgradeError error 0.)
Error Code:
Installed as service via tailscale videos and this script
from: video-caddy-custom-domains/caddy at main · tailscale-dev/video-caddy-custom-domains · GitHub
#!/bin/bash
# downloads the caddy binary with the cloudflare plugin enabled
# must be run as root
caddy_path="/usr/local/bin/caddy"
if [ "$EUID" -ne 0 ]
then echo "Please run as root"
exit
fi
if [ -f "$caddy_path" ]; then
echo "$caddy_path exists..."
echo "Nothing to do. Exiting."
exit 1
else
curl "https://caddyserver.com/api/download?os=linux&arch=amd64&p=github.com%2Fcaddy-dns%2Fcloudflare" -o $caddy_path
chmod +x $caddy_path
fi
Type=notify
ExecStart=/usr/local/bin/caddy run --environ --config /etc/caddy/Caddyfile
ExecReload=/usr/local/bin/caddy reload --config /etc/caddy/Caddyfile --force
PrivateDevices=yes
ubuntu server running in vm on proxmox host
(cloudflare) {
dns cloudflare
# adguard
adguard.two.friedbananapies.org {
reverse_proxy http://192.168.68.2
import cloudflare
# ha
ha.two.friedbananapies.org {
reverse_proxy http://192.168.68.195:8123
import cloudflare
