Home lab external/internal switch
I am trying my best to describe my problem here - at first: I am one of the poor people behind a CGNAT and so I am trying to get my home lab, or at least some services, exposed to the www for ease of use.
I bought a VPS server with a static external IP and installed Wireguard there - I set up a small Wireguard client on my home lab as a Proxmox LXC which accepts all incoming things from my VPS.
This connection is working, I can ping everything in my home lab over the tunnel and I can ping out over the tunnel - at least from the Wireguard Client machine.
I went through the configuration of several reverse proxy services/applications and found Caddy the easiest to use.
I installed Caddy to the VPS server and to the Wireguard Client machine and hoped that those two will work together to achieve everything I want, but little did I know. And it brought me down to an issue with Caddy.
Now I want to achieve, that the external communication (everything when I am not at home) is going through the VPS → WG → WG-Client → SERVICE (this is working).
And I also want to achieve, that the internal communication (everything when I am at home) is just going Smartphone/Computer → WG-Client → SERVICE (this is not working).
I got told, that this must be a DNS issue, but every time I set my DNS rewrites in my AdGuard to rewrite my *.mydomain.com to the WG-Client, I get a ERR_CONNECTION_REFUSED.
I hope the following picture will help understanding everything.
This is the output of curl -vL to nc.mydomain.com on the WG client
curl -vL nc.mydomain.com
*   Trying 192.168.178.253:80...
* Connected to nc.mydomain.com (192.168.178.253) port 80 (#0)
> GET / HTTP/1.1
> Host: nc.mydomain.com
> User-Agent: curl/7.74.0
< HTTP/1.1 302 Found
< Cache-Control: no-store, no-cache, must-revalidate
< Content-Length: 0
< Content-Security-Policy: default-src 'self'; script-src 'self' 'nonce-OUkwVVNXd1MwS0djejZYdGI4c0xMU3VJeWFuYjBoZGFrOEk5N0xQcmQrUT06amVzc0JTVjVwK3ZNaS9PNlBabENWMExmNXR1UW5FRUsxN2QvdHRLWlByND0='; style-src 'self' 'unsafe-inline'; frame-src *; img-src * data: blob:; font-src 'self' data:; media-src *; connect-src *; object-src 'none'; base-uri 'self';
< Content-Type: text/html; charset=UTF-8
< Date: Sat, 13 Apr 2024 10:42:49 GMT
< Expires: Thu, 19 Nov 1981 08:52:00 GMT
< Location: https://nc.mydomain.com/login
< Pragma: no-cache
< Referrer-Policy: no-referrer
< Server: Caddy
< Server: Apache
< Set-Cookie: oc_sessionPassphrase=a5rpOec90HzxsM7i6Zhmbtg%2BIf2%2BKlq9b3zVRW4h3dnWEk2i24KPxYA2hua%2Ba%2B%2Bejr4QhWbyokYhly50x%2F2%2F3HONCeT0bBYCgNjkm7EGKcV7Iyr4KIimNqtSQtSRXOtv; path=/; secure; HttpOnly; SameSite=Lax
< Set-Cookie: __Host-nc_sameSiteCookielax=true; path=/; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=lax
< Set-Cookie: __Host-nc_sameSiteCookiestrict=true; path=/; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=strict
< Set-Cookie: ocoa4aex63uo=34jpunags6ud54edft52gadnl7; path=/; secure; HttpOnly; SameSite=Lax
< X-Content-Type-Options: nosniff
< X-Frame-Options: SAMEORIGIN
< X-Permitted-Cross-Domain-Policies: none
< X-Robots-Tag: noindex, nofollow
< X-Xss-Protection: 1; mode=block
* Connection #0 to host nc.mydomain.com left intact
* Clear auth, redirects to port from 80 to 443Issue another request to this URL: 'https://nc.mydomain.com/login'
*   Trying 192.168.178.253:443...
* connect to 192.168.178.253 port 443 failed: Verbindungsaufbau abgelehnt
* Failed to connect to nc.mydomain.com port 443: Verbindungsaufbau abgelehnt
* Closing connection 1
curl: (7) Failed to connect to nc.mydomain.com port 443: Verbindungsaufbau abgelehnt
This is the cur -vL output from nc.mydomain.com on the VPS (external way):
(I stripped the HTML-Part)
* Connected to nc.mydomain.com (1.2.3.4) port 80 (#0)
> GET / HTTP/1.1
> User-Agent: curl/7.88.1
< Connection: close
< Server: Caddy
< Date: Sat, 13 Apr 2024 10:58:48 GMT
< Content-Length: 0
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
* Closing connection 0
* Issue another request to this URL: 'https://nc.mydomain.com/'
*   Trying 1.2.3.4:443...
* Connected to nc.mydomain.com (1.2.3.4) port 443 (#1)
* ALPN: offers h2,http/1.1
} [5 bytes data]
} [512 bytes data]
*  CApath: /etc/ssl/certs
{ [5 bytes data]
{ [122 bytes data]
{ [15 bytes data]
{ [2382 bytes data]
{ [78 bytes data]
{ [36 bytes data]
} [1 bytes data]
} [36 bytes data]
* ALPN: server accepted h2
*  subject: CN=nc.mydomain.com
*  start date: Apr 12 11:15:48 2024 GMT
*  expire date: Jul 11 11:15:47 2024 GMT
*  subjectAltName: host "nc.mydomain.com" matched cert's "nc.mydomain.com"
} [5 bytes data]
* using HTTP/2
* h2h3 [:method: GET]
* h2h3 [:path: /]
* h2h3 [:scheme: https]
* h2h3 [:authority: nc.mydomain.com]
* h2h3 [user-agent: curl/7.88.1]
* h2h3 [accept: */*]
* Using Stream ID: 1 (easy handle 0x556e2c15a790)
} [5 bytes data]
> GET / HTTP/2
> accept: */*
{ [5 bytes data]
{ [122 bytes data]
< HTTP/2 302
< cache-control: no-store, no-cache, must-revalidate
< content-security-policy: default-src 'self'; script-src 'self' 'nonce-dUsyeW9qbklkV2lLQWZGQmRFeERCRFlNZnR2amRtWWlXeVBZSnIyWkExbz06aTUzY3pHK0ZKeUxUY0lja1BYVVRTMHh1RitQTUl3bHVibHVOVXU2eVN5az0='; style-src 'self' 'unsafe-inline'; frame-src *; img-src * data: blob:; font-src 'self' data:; media-src *; connect-src *; object-src 'none'; base-uri 'self';
< content-type: text/html; charset=UTF-8
< date: Sat, 13 Apr 2024 10:58:48 GMT
< expires: Thu, 19 Nov 1981 08:52:00 GMT
< location: https://nc.mydomain.com/login
< pragma: no-cache
< referrer-policy: no-referrer
< server: Caddy
< server: Caddy
< server: Apache
< set-cookie: oc_sessionPassphrase=ttW0l%2FVHeyf3BIm%2BSt3aVXZl5i1wdnSiuY3fu24%2BHlPfagY9%2BJdGMnyBhSKMqxmNpwb1sFK%2BS0IkuA2%2BrYBWPYdUjabkybaANYWNeL5arcxio51PTwju3zIK4UXt%2B5kj; path=/; secure; HttpOnly; SameSite=Lax
< set-cookie: __Host-nc_sameSiteCookielax=true; path=/; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=lax
< set-cookie: __Host-nc_sameSiteCookiestrict=true; path=/; httponly;secure; expires=Fri, 31-Dec-2100 23:59:59 GMT; SameSite=strict
< set-cookie: ocoa4aex63uo=a34c133374rlbplais8d3ltkg0; path=/; secure; HttpOnly; SameSite=Lax
< strict-transport-security: max-age=63072000
< x-frame-options: SAMEORIGIN
< x-permitted-cross-domain-policies: none
< x-robots-tag: noindex, nofollow
< x-xss-protection: 1; mode=block
< content-length: 0
{ [0 bytes data]
* Connection #1 to host nc.mydomain.com left intact
* Issue another request to this URL: 'https://nc.mydomain.com/login'
* Found bundle for host: 0x556e2c152190 [can multiplex]
* Re-using existing connection #1 with host nc.mydomain.com
* h2h3 [:path: /login]
* Using Stream ID: 3 (easy handle 0x556e2c15a790)
} [5 bytes data]
> GET /login HTTP/2
> accept: */*
{ [5 bytes data]
< HTTP/2 200
< cache-control: no-cache, no-store, must-revalidate
< content-security-policy: default-src 'none';base-uri 'none';manifest-src 'self';script-src 'self';style-src 'self' 'unsafe-inline';img-src 'self' data: blob: https://*.tile.openstreetmap.org;font-src 'self' data:;connect-src 'self';media-src 'self';frame-src 'self';frame-ancestors 'self';form-action 'self'
< feature-policy: autoplay 'self';camera 'none';fullscreen 'self';geolocation 'none';microphone 'none';payment 'none'
< pragma: no-cache
< server: Caddy
< server: Caddy
< server: Apache
< set-cookie: oc_sessionPassphrase=TWd2ELZq7XpoacpP99eyJiOYk6NxQ6igFIzvOBvvuumFO3Q16ZHCBptsSbU7xASauPL1UIhVUr%2Frr9Q%2BrLdnmlj34hTjtGYzJ05ver5uxKye0tbMNL2llJ4rWpHXupkg; path=/; secure; HttpOnly; SameSite=Lax
< set-cookie: ocoa4aex63uo=kccrehp5la8rn57bj2913kqkhe; path=/; secure; HttpOnly; SameSite=Lax
< x-request-id: yyLgXzH0OWmAA7Prw2My
{ [5 bytes data]
100 12185    0 12185    0     0  59047      0 --:--:-- --:--:-- --:--:-- 59047
System on VPS:
Operating System: Debian GNU/Linux 12 (bookworm)
          Kernel: Linux 6.1.0-18-cloud-amd64
    Architecture: x86-64
System on WG client:
          Kernel: Linux 6.2.16-19-pve
Installed Caddy with the help of the standard docs:
sudo apt update
sudo apt install caddy
WG client
Caddyfile:
# (headers) {
#       header {
#               Permissions-Policy interest-cohort=()
#               Strict-Transport-Security "max-age=31536000; includeSubdomains"
#               X-XSS-Protection "1; mode=block"
#               X-Content-Type-Options "nosniff"
#               X-Robots-Tag noindex, nofollow
#               Referrer-Policy "same-origin"
#               Content-Security-Policy "frame-ancestors mydomain.com *.mydomain.com"
#               -Server
#               Permissions-Policy "geolocation=(self mydomain.com *.mydomain.com), microphone=()"
# The Caddyfile is an easy way to configure your Caddy web server
# domain name.
# :80 {
#       Set this path to your site's directory.
#       root * /usr/share/caddy
#       Enable the static file server.
#       file_server
# php_fastcgi localhost:9000
#       disable_auto_cert_gen
http://nc.mydomain.com {
        reverse_proxy http://192.168.178.228
WG config:
[Interface]
Address = 10.0.0.2/24
DNS = 192.168.178.250
#SaveConfig = true
PostUp = iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE; iptables -A FORWARD --in-interface wg0 -j ACCEPT
PostDown = iptables -D FORWARD --in-interface wg0 -j ACCEPT; iptables -t nat -D POSTROUTING -o eth0 -j MASQUERADE
PrivateKey = <keyhere>
[Peer]
PublicKey = <keyhere>
AllowedIPs = 0.0.0.0/0
Endpoint = 1.2.3.4:55107
PersistentKeepalive = 25
VPS:
Caddyfile:
(hsts) {
  header Strict-Transport-Security max-age=63072000
# (headers) {
#       header {
#               -Server
# domain name.
home.mydomain.com {
nc.mydomain.com {
        reverse_proxy http://10.0.0.2
        import hsts
vw.mydomain.com {
        reverse_proxy http://192.168.178.227
        import hsts
WG config:
[Interface]
Address = 10.0.0.1/24
#SaveConfig = true
PostUp = iptables -A FORWARD -i wg0 -j ACCEPT; iptables -t nat -A POSTROUTING -o ens6 -j MASQUERADE
PostDown = iptables -D FORWARD -i wg0 -j ACCEPT; iptables -t nat -D POSTROUTING -o ens6 -j MASQUERADE
ListenPort = 55107
[Peer]
AllowedIPs = 10.0.0.2/32, 192.168.178.0/24
I tried the Caddy configs from the following page, but that did not result in any success, I only referred to the Caddyfiles, the WG tunnel is set up a bit different: Using Wireguard to Tunnel All Traffic through a VPS to Home
Hopefully, I have everything sorted out by now. If there are any questions, please let me know, otherwise I hope someone can help me because she/he had the same problem and found a solution to this.
I would first try to solve why your internal network can’t get to the VPS host.
It’s because it is a layer 3 routing problem
Your internal network doesn’t know there is a wireguard network 10.0.0.0/24. So any packet being sent to this network will take the default route and go to your router 192.168.178.X. This router doesnt know 10.0.0/24 either and your paket gets dropped.
Now you could put a route on that default router to point it to your wireguard server, but then another problem strikes, layer 2. With the arp table, the return paket will not go back to the router, but to the client directly. That will create an assymetrical routing problem that makes TCP fail.
The best way out is to have wireguard on your primary routing instance. Otherwise you need two routing instances in your network, which is quite complicated for a simple setup.
Edit:
Another option is to put a static route on each client in your network that points to the wireguard net, but thats really hard to manage and not all devices support that.
Edit2:
192.168.178.0/24 and CG NAT sounds like a Fritzbox. With that your options as router are severely limited with such a complex setup.
Thank you for the explanation - I tried using my (beloved and at the same time hated) FritzBox as an endpoint for the Wireguard connection, but that does not solve any problems.
Even tough I have a DNS rewrite active on AdGuard, which directly points to the WG client (192.168.178.253), which also has Caddy installed and serves the websites to external without any issue but internal it is not working, the connection doesn’t get accepted.
And the path VPS → WG/Caddy client → is working without the rewrite but then the way of the connection is as follows:
(Client in Homenet) → Router → external Internet → VPS/Caddy → WG tunnel → WG/Caddy → service
And I want it as follows:
(Client in Homenet) → Router → WG/Caddy → service
So that the internal communication is kept inside.
Am I missing something here from you? Can you explain further? I understand, that the network 10.0.0.0/24 is totally capsuled from anything else and yes, no other client on my home network knows anything about this and it should stay that way.
I can ping every service with the respective IP or hostname inside my home network.
The ns lookups are as follows (192.168.178.1 is the router, .253 is the Caddy/WG server, 1.2.3.4 is the ip of the VPS):
  • 192.168.178.1 is the router
  • 192.168.178.253 is the Caddy/WG server
  • 1.2.3.4 is the external IP of the VPS
with rewrite enabled:
nslookup nc.mydomain.com 192.168.178.1
Server:  fritz.box
Address:  192.168.178.1
Non-authoritative answer:
Address:  192.168.178.253
with rewrite disabled:
Snserver:  fritz.box
Address:  1.2.3.4
One of the possible problems could be the 0.0.0.0/0 in allowed IPs of the Wireguard Caddy server. It creates a default route into the Wireguard tunnel.
Try to restrict it to IPs other than 192.168.178.0/24 addresses and see if that improves things.
There is a Wireguard Allowed IP calculator for this, since you cant invert the allowed IPs in wg.
If you input 0.0.0.0/0 as allowed and 192.168.178.0/24 as non allowed, you get a list like this:
AllowedIPs = 0.0.0.0/1, 128.0.0.0/2, 192.0.0.0/9, 192.128.0.0/11, 192.160.0.0/13, 192.168.0.0/17, 192.168.128.0/19, 192.168.160.0/20, 192.168.176.0/23, 192.168.179.0/24, 192.168.180.0/22, 192.168.184.0/21, 192.168.192.0/18, 192.169.0.0/16, 192.170.0.0/15, 192.172.0.0/14, 192.176.0.0/12, 192.192.0.0/10, 193.0.0.0/8, 194.0.0.0/7, 196.0.0.0/6, 200.0.0.0/5, 208.0.0.0/4, 224.0.0.0/3
EDIT:
I bet you’re surprised I sense Fritzboxes instantly. :rofl:
Fritzboxes are easy to see, if you know the metric of their system.
Nonetheless, I tried adding 192.168.178.0/24 to the allowed list and the result is, that Wireguard is telling me, that the file exists. Probably due to the fact, that THIS explicit route got specified in the servers allow list.
Here the error:
Screenshot 2024-04-13 204730
BUT, to be fair, having 0.0.0.0/0 specified in the Wireguard config sends every bit of traffic through the tunnel.
Here a screenshot of the text from the allowed IPs calculator:
What I added now is the IPv6 part, but that did not solve my error.
I don’t understand, the list of allowed IPs I posted above should have been set as allowed IPs on the Caddy Wireguard VM.
It sends all traffic through the tunnel except 192.168.178.0/24
Ah, sorry - now I get it. Will try.
Edit: results in HTTP_ERROR_502 Bad Gateway.
And what happens if you turn wireguard off? Does Caddy still not serve locally?
No, nothing - connection refused.
Edit:
What I also tried was copying the certs to the receiving Caddy server but nothing.
I’m not sure how to help anymore, maybe somebody else has an idea.
Maybe some pointers:
  • Check the firewall settings of the caddy wireguard host
  • Test with tcpdump if it receives the packets, and where the response packets go
  • Check with sockstat or netstat if Caddy listens on all interfaces/ip addresses, or its bound to just the wireguard interface.
Otherwise :man_shrugging: its a complex setup. I would go from the lowest layers up to the highest. Without having the basic network working properly I wouldn’t try to troubleshoot a layer 7 application.
