Docker, see above.
See above
I am running into random websocket issues like SignalR
docker logs caddy 2>&1 | grep hijack
{"level":"error","ts":1649860704.838475,"logger":"http.handlers.reverse_proxy","msg":"hijack failed on protocol switch","error":"method not implemented"}
{"level":"error","ts":1649860727.7193956,"logger":"http.handlers.reverse_proxy","msg":"hijack failed on protocol switch","error":"method not implemented"}
{"level":"error","ts":1649860741.660313,"logger":"http.handlers.reverse_proxy","msg":"hijack failed on protocol switch","error":"method not implemented"}
{"level":"error","ts":1649860825.063669,"logger":"http.handlers.reverse_proxy","msg":"hijack failed on protocol switch","error":"method not implemented"}
{"level":"error","ts":1649860825.1800597,"logger":"http.handlers.reverse_proxy","msg":"hijack failed on protocol switch","error":"method not implemented"}
{"level":"error","ts":1649860945.6200492,"logger":"http.handlers.reverse_proxy","msg":"hijack failed on protocol switch","error":"method not implemented"}
{"level":"error","ts":1649860945.6202252,"logger":"http.handlers.reverse_proxy","msg":"hijack failed on protocol switch","error":"method not implemented"}
{"level":"error","ts":1649861065.953286,"logger":"http.handlers.reverse_proxy","msg":"hijack failed on protocol switch","error":"method not implemented"}
{"level":"error","ts":1649861065.9573364,"logger":"http.handlers.reverse_proxy","msg":"hijack failed on protocol switch","error":"method not implemented"}
{"level":"error","ts":1649861186.2857592,"logger":"http.handlers.reverse_proxy","msg":"hijack failed on protocol switch","error":"method not implemented"}
{"level":"error","ts":1649861186.297892,"logger":"http.handlers.reverse_proxy","msg":"hijack failed on protocol switch","error":"method not implemented"}
Debug logs:
https://dulanic.com/files/caddy.log
Searched online and in forums for this error. Also looked at code on github, but couldn’t identify much besides that it seems to be websocket related? Also looked at Radarr System | WikiArr but this looks to be V1 stuff since V2 has upgrading connections integrated by default.
