Caddy v2.4.5
Download binary file.
Ubuntu
Hi, what is Nginx proxy_cache_convert_head in Caddy?
Caddy is converting HEAD requests to GET requests.
Please properly fill out the help topic template. Do not delete any sections.
I don’t understand your question. Please elaborate. What behaviour are you seeing exactly, and what did you expect? Use curl -v to show what you mean.
@francislavoie Sorry, I don’t receive the email about your reply.
For example, I use HEAD request to check the file is exist:
curl --head https://caddy-forum-uploads.s3.amazonaws.com/original/2X/3/3859a874d26640df74a3b951d8052a3c3e749eed.png
OR
check file has existed in Minio server with the S3 client
const res = await s3.send(
new HeadObjectCommand({
Key: key,
Bucket: bucket
The request is failed with Caddy as a reverse proxy. And when I saw Caddy logs, the request method was shown as GET.
This bug is same as statObject always returns “'AccessDenied” · Issue #842 · minio/minio-js (github.com)
I want to ask what I need to config in Caddy to prevent Caddy convert the request from HEAD => GET
Again, please completely fill out the help topic template. I need to see what your Caddyfile looks like, and what’s in your logs.
Sorry for wasting your time. I have found out Cloudflare modify the HEAD request to GET request.
Please close this issue.
