Help with tomcat reverse proxy
2.4.5
caddy run --watch
REHL 8
caddy run --watch
n/a
        http_port 8080
        https_port 8443
:8443 {
        tls /my_home/certs/server.pem /my_home/certs/server.key
        encode zstd gzip
        root * /my_home/web
        templates
        file_server browse
        reverse_proxy /apps/* localhost:8888
Unable to get to Tomcat’s default page and Tomcat manager.
There are no error messages in the logs.
I can access the root https://hostname:8443/ and see the index.html
When I try https://hostname:8443/apps I get 404
When I try https://hostname:8443/apps/ I get Tomcat’s 404 error "The requested resource [/apps/] is not available
I’ve tried using “route” and using “ui strip_prefix” but couldn’t get the results I was expecting.
You could try this:
	http_port 8080
	https_port 8443
:8443 {
	encode zstd gzip
	handle_path /apps* {
		reverse_proxy localhost:8888
		root * /my_home/web
		templates
		file_server browse
Using handle blocks makes sure that reverse_proxy and file_server routes are mutually exclusive. And handle_path has built-in uri strip_prefix logic.
That was because /apps doesn’t match /apps/* because your matcher expects at least a slash after /apps.
It’s worth mentioning though, not all backend apps are properly set up for, or configured to handle requests to a different base path. See this article for additional reading on the topic:
Thank you for the quick response.
With your recommended config changes I’m able to access the Tomcat default (home) page however, when I click on “Manager App” or any other links on that default page it fails. I experienced similar issue using “handle” with “strip_prefix”. I’ll go through the article that you’ve shared, maybe the solution will be in there.
The solution is really “just use a subdomain for it”, if you can’t reconfigure the tomcat app to handle /apps paths.
Thank you!
