Help with subdomain config in Caddyfile
Unable to get Caddy to restart with a subdomain.
{"level":"info","ts":1696899151.1037645,"msg":"using provided configuration","config_file":"/usr/local/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
Error: adapting config using caddyfile: /usr/local/etc/caddy/Caddyfile:32: unrecognized directive: owncloud.voncarmo.com
Error: caddy process exited with error: exit status 1
3. Caddy version: caddy-2.7.4_1
Installed on FreeBSD 13.2-RELEASE-p2 via packages.
a. System environment: as above
service caddy restart
n/a
# domain name.
voncarmo.com {
                # Set this path to your site's directory:
                root * /usr/local/www/voncarmo.com
                # Enable the static file server:
                # Set up a reverse proxy:
                # Serve a PHP site through php-fpm:
                # php_fastcgi localhost:9000
                php_fastcgi unix//var/run/php81.sock
                # Enable logging:
                                # Caddy's structured log format:
                                format json
                                # Or, for Common Log Format:
                                # format single_field common_log
                owncloud.voncarmo.com {
                root * /www/local/www/owncloud
# Caddy will automatically obtain ACME certs for domains
# example.com {
#     root * /path/to/example.com
Each domain needs to be within its own site block, like this…
voncarmo.com {
                # Enable logging:
                                format json
cheers… just needed to move that little sucker.
