Help with reverse proxy settings for NextJS
I have two issues, one is related to read / write buffers tailored to NextJS and the other is related to rate limiting. We are running Caddy behind another loadbalancer (managed loadbalancer from a cloud provider) and routing traffic to 4 containers running NextJS.
  1. Rate limiting:
    I have been tinkering with rate limiting because we get hammered by bots sometime and the Google bot parts seem to work fine, but the “normal users” part is currently not working (thats why its commented out), we get rate limited to fast and I think this is due to the initial request triggering multiple other requests so the rate limit hits to soon. Is it possible to exclude specifics paths?
  2. Read / Write buffers / settings for NextJS.
    I have been trying to figure out what the “optimal” settings are for a reverse proxy and nextjs but have come up a bit short. Are the values we are using fine? Could they be tweaked?
No errors.
We have installed caddy using docker and a image we built ourselves that includes GitHub - mholt/caddy-ratelimit: HTTP rate limiting module for Caddy 2 · GitHub
Ubuntu 24.04, Docker version 28.0.4, build b8034c0
16 Cores, 24gb memory
Our docker compose
    image: ghcr.io/<redacted>/caddy:latest
    restart: always
      - "./Caddyfile:/etc/caddy/Caddyfile:ro"
      - "www:/var/www/goaccess/:ro"
      - "log:/var/log/caddy/"
    deploy:
      resources:
        limits:
          cpus: '4'
          memory: 3G
        reservations:
          cpus: '2'
          memory: 3G
    depends_on:
      - app-1
      - app-2
      - app-3
      - app-4
      - app_network
  app-1:
    container_name: <redacted>-app-1
    image: ${image}
    restart: always
    env_file: /root/.env
      - INSTANCE_ID=1
    expose:
      - "3000"
      - app_network
    volumes: []
    deploy:
      resources:
        limits:
          cpus: '3'
          memory: 5G
        reservations:
          cpus: '3'
          memory: 5G
    healthcheck:
      test: ["CMD", "wget", "-q", "--spider", "http://0.0.0.0:3000/api/health" ]
      interval: 15s
      timeout: 5s
      retries: 3
      start_period: 45s
  app-2:
    container_name: <redacted>-app-2
    image: ${image}
    restart: always
      - INSTANCE_ID=2
    expose:
      - "3000"
      - app_network
    volumes: []
    deploy:
      resources:
        limits:
          cpus: '3'
          memory: 5G
        reservations:
          cpus: '3'
          memory: 5G
    healthcheck:
      interval: 15s
      timeout: 5s
      retries: 5
      start_period: 30s
  app-3:
    container_name: <redacted>-app-3
    image: ${image}
    restart: always
      - INSTANCE_ID=3
    expose:
      - "3000"
      - app_network
    volumes: []
    deploy:
      resources:
        limits:
          cpus: '3'
          memory: 5G
        reservations:
          cpus: '3'
          memory: 5G
    healthcheck:
      interval: 15s
      timeout: 5s
      retries: 5
      start_period: 30s
  app-4:
    container_name: <redacted>-app-4
    image: ${image}
    restart: always
      - INSTANCE_ID=4
    expose:
      - "3000"
      - app_network
    volumes: []
    deploy:
      resources:
        limits:
          cpus: '3'
          memory: 5G
        reservations:
          cpus: '3'
          memory: 5G
    healthcheck:
      interval: 15s
      timeout: 5s
      retries: 5
      start_period: 30s
  app_network:
    driver: bridge
  www:
  log:
        admin off
        auto_https off
        servers {
                listener_wrappers {
                        proxy_protocol {
                                timeout 10s
                                allow 10.0.0.0/8 172.16.0.0/12 192.168.0.0/16 127.0.0.0/8
                timeouts {
                        read_body 30s
                        read_header 30s
                        write 30s
                        idle 120s
                trusted_proxies static private_ranges
        @googlebot {
                header User-Agent *Googlebot*
        handle /api/health {
                reverse_proxy app-1:3000 app-2:3000 app-3:3000 app-4:3000 {
                        health_uri /api/health
                        health_interval 15s
                        health_timeout 5s
                        health_status 200
                                read_buffer 128KB
                                write_buffer 128KB
                                max_response_header 128KB
        handle @googlebot {
                rate_limit {
                        zone googlebot_zone {
                                key {http.request.remote_ip}
                                events 15
                                window 1m
                                status_code 429
                        lb_policy round_robin
                        health_interval 15s
                        health_timeout 5s
                        health_status 200
                        fail_duration 5s
                        max_fails 3
                        unhealthy_status 503
                                dial_timeout 30s
                                response_header_timeout 30s
                                keepalive 30s
                                keepalive_idle_conns 10
                                max_response_header 2MB
                                read_buffer 512KB
                                write_buffer 512KB
                # Higher limit for normal users
                # rate_limit {
                #     zone normal_users_zone {
                #         key {http.request.client_ip}
                #         events 30 # Total should be 120 since we have 4 servers running caddy.
                #         window 1m
                #         status_code 429
                        health_interval 15s
                        health_timeout 5s
                        health_status 200
                        fail_duration 5s
                        max_fails 3
                                dial_timeout 30s
                                keepalive 30s
                                max_response_header 10MB
                                read_buffer 2MB
                                write_buffer 128KB
                format json
                        roll_size 10gb
                        roll_keep 10
                        roll_keep_for 2160h
        handle_errors {
                @is_rate_limited expression {http.error.status_code} == 429
                handle @is_rate_limited {
                        respond "Rate limit exceeded. Please try again later." 429 {
                                close
                        respond "Service temporarily unavailable. Please try again." 503
The rate_limit module supports matchers in the match sub-directive. You can also wrap the whole thing in a handle for included/excluded paths, however you want to draw the logic.
This should actually be either {client_ip} or {http.vars.client_ip}
This is not something we can advise on because it’s extremely specific to your app.
