Help with reverse proxy on ONVIF camera
v2.4.0 h1:yHnnbawH2G3ZBP2mAJF4XBLnJanqhULLP/wu01Qi9Io=
Caddy is run as a service using JSON API on Ubunto 20.04
systemd
It’s automatically started at boot up time
n/a
I am just posting the relevant information here as it’s too big for the forums to handle:
              "handle": [
                  "handler": "subroute",
                  "routes": [
                      "handle": [
                          "handler": "rewrite",
                          "strip_path_prefix": "/axis-home"
                      "handle": [
                          "handler": "reverse_proxy",
                          "headers": {
                            "request": {
                              "set": {
                                "Access-Control-Allow-Credentials": [
                                  "true"
                                "Access-Control-Allow-Headers": [
                                  "Cache-Control,Content-Type"
                                "Access-Control-Allow-Origin": [
                                "X-Forwarded-Proto": [
                                  "{http.request.scheme}"
                                "X-Real-Ip": [
                                  "{http.request.remote.host}"
                          "upstreams": [
                              "dial": "192.168.0.78:80"
              "match": [
                  "path": [
                    "/axis-home/*"
I get a 502 Bad Gateway when trying to access
From the journal:
May 18 08:02:08 jeff-UX510UX caddy[1103]:
  "level":"error",
  "ts":1621346528.6609566,
  "logger":"http.log.error",
  "msg":"dial tcp 192.168.0.78:80: connect: no route to host",
  "request":
    "remote_addr":"127.0.0.1:46620",
    "proto":"HTTP/1.1",
    "method":"POST",
    "host":"localhost",
    "uri":"/axis-home/onvif/device_service",
    "headers":
      "Connection":["close"],
      "Content-Type":["application/soap+xml; charset=utf-8; action=http://www.onvif.org/ver10/device/wsdl/GetSystemDateAndTime"],
      "Accept":["*/*"],
      "Content-Length":["299"],
      "User-Agent":["node-fetch/1.0 (+https://github.com/bitinn/node-fetch)"],
      "Accept-Encoding":["gzip,deflate"]
  "duration":3.06392252,
  "status":502,
  "err_id":"h29psppf5",
  "err_trace":"reverseproxy.statusError (reverseproxy.go:852)"
The code I am using to access the camera directly via IP address works fine. Once I try to use the reverse proxy, I get the 502 Bad Gateway.
The situation here is resolved. Unfortunately, the ONVIF camera does not have a static IP and had changed.
I have one more (small?) issue that I need to content with.
Typically, you can request an image from an ONVIF camera and the URL looks like this:
http://192.168.0.78/onvif-cgi/jpg/image.cgi?resolution=1280x720&compression=30
The one above works with no issues.
But, using the reverse proxy, this is the URL:
'http://localhost/axis-home/onvif-cgi/jpg/image.cgi?resolution=1280x720&compression=30'
(The JSON is on original message - part d, above)
I am wondering if I have the rewrite handler done properly to handle the query/search portion of the Uri?
