ducky
(Roger Duckworth)
March 26, 2022, 4:13pm
#1
Current Caddyfile.
Caddy Version 2.4.6
I’m quite confused trying to figure out how to switch to this new formatting plugin. The syntax is different than what I’m used to. If someone could help me switch I’d appreciate it as I use this common log to hook into my fail2ban setup.
email dubu@bub.cat
acme_ca https://acme.zerossl.com/v2/DV90
www.a.bub.cat {
redir https://a.bub.cat
a.bub.cat {
reverse_proxy localhost:50694
output file /var/log/caddy/void.log
encode {
gzip 6
br 5
import security.conf
handle_errors {
rewrite * /{http.error.status_code}
reverse_proxy https://http.cat {
header_up Host http.cat
Assuming you have a caddy build with GitHub - caddyserver/transform-encoder: Log encoder module for custom log formats included, you can do the following:
- format single_field common_log
+ format transform "{common_log}"
Taken from the modules’ README: transform-encoder#apache-common-log-format-example [permalink ]
You should use that plugin with v2.5.0-beta.1
, it’s meant to be used with that version (or later), not with v2.4.6
ducky
(Roger Duckworth)
March 26, 2022, 7:38pm
#4
Hey thanks a lot guys. It’s working now. Appreciate the help!
system
(system)
closed
April 25, 2022, 4:13pm
#5
