Help with proxying to php in a docker container
1. Output of caddy version:
Debian Bullsys
systemd
sudo systemctl start caddy
Type=notify
	email my.email
		output file /var/log/caddy/caddy.log
		level info
https://fyrfli.org {
		output file /var/log/fyrfli-org.log
	root * /srv/public
	php_fastcgi localhost:9000 {
		root /srv/public
Every other host in the Caddyfile works just fine so snipped out those lines for clarity (It’s a long file)
When I load up https://fyrfli.org, I get a blank page and the following in the caddy.log file (prettified for readability):
    "level": "error",
    "ts": 1671076650.9727628,
    "logger": "http.log.error.log7",
    "msg": "dialing backend: dial tcp 127.0.0.1:9000: connect: connection refused",
    "request": {
        "remote_ip": "69.10.106.221",
        "remote_port": "51881",
        "proto": "HTTP/2.0",
        "method": "GET",
        "host": "fyrfli.org",
        "uri": "/",
        "headers": {
            "Accept-Encoding": [
                "gzip, deflate, br"
            "Dnt": [
                "1"
            "Sec-Fetch-User": [
                "?1"
            "Sec-Gpc": [
                "1"
            "Te": [
                "trailers"
            "Accept": [
                "text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"
            "Accept-Language": [
                "en,en-US;q=0.5"
            "Sec-Fetch-Dest": [
                "document"
            "Sec-Fetch-Mode": [
                "navigate"
            "Sec-Fetch-Site": [
                "none"
            "User-Agent": [
                "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:107.0) Gecko/20100101 Firefox/107.0"
                "1"
        "tls": {
            "resumed": false,
            "version": 772,
            "cipher_suite": 4865,
            "proto": "h2",
            "server_name": "fyrfli.org"
    "duration": 0.000822463,
    "status": 502,
    "err_id": "givurjirb",
    "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"
As stated above, error in the caddy log is:
    "level": "error",
    "request": {
        "remote_ip": "my-ip-address",
        "method": "GET",
        "uri": "/",
        "headers": {
                "gzip, deflate, br"
            "Dnt": [
                "1"
            "Sec-Fetch-User": [
                "?1"
            "Sec-Gpc": [
                "1"
            "Te": [
                "trailers"
            "Accept": [
                "en,en-US;q=0.5"
            "Sec-Fetch-Dest": [
                "document"
            "Sec-Fetch-Mode": [
                "navigate"
            "Sec-Fetch-Site": [
                "none"
            "User-Agent": [
                "1"
        "tls": {
            "resumed": false,
            "version": 772,
            "proto": "h2",
    "status": 502,
  • I’ve tried using the reverse_proxy directive to the :80 port in the docker container.
  • I’ve tried adding try_files {path} {path}/index.php index.php to the Caddyfile section
  • I’ve tried adding the container name instead of localhost or 127.0.0.1 or nothing (i.e. php_fastcgi :9000
I either get the same blank page or a ā€œFile not foundā€. However, I can browse the files in the public directory (I was able to load up https://fyrfli.org/robots.txt and see the contents - which is a whole other issue I am going to need to solve later)
I am at my wits end. This is easy with nginx and php-fpm on the host, i.e.:
location ~ \.php$ {
    fastcgi_split_path_info ^(.+\.php)(/.+)$;
    if (!-f $document_root$fastcgi_script_name) {
        return 404;
    fastcgi_pass unix:/run/php-fpm/php-fpm.sock;
    fastcgi_read_timeout 30m;
    fastcgi_param PATH_INFO $fastcgi_path_info;
    fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
    fastcgi_index index.php;
    include /etc/nginx/fastcgi_params;
But I cannot seem to translate this to work with caddy → php-fpm in a docker container.
Help?!
Howdy @fyrfli, welcome to the Caddy community.
How do you run your PHP container?
The configuration of your Docker containers is 100% critical to determining how to access, and reverse proxy to, a containerized PHP-FPM.
This would work equally well for Caddy if you still had PHP on the host, too, with just:
php_fastcgi unix//run/php-fpm/php-fpm.sock
My bad. It’s an invoice ninja container. Here is the docker run command I use:
docker run -d \
  --name invoiceninja \
  --restart=unless-stopped \
  -v /srv/public:/var/www/app/public \
  -v /srv/storage:/var/www/app/storage \
  -e APP_ENV='production' \
  -e APP_DEBUG=0 \
  -e APP_URL='http://fyrfli.org' \
  -e APP_KEY='app_key' \
  -e APP_CIPHER='AES-256-CBC' \
  -e DB_TYPE='mysql' \
  -e DB_STRICT='false' \
  -e DB_HOST='172.17.0.1' \
  -e DB_DATABASE='db' \
  -e DB_USERNAME='dbuser' \
  -e DB_PASSWORD='dbpassword' \
  -p '8010:80' \
  invoiceninja/invoiceninja
That container does not expose port 9000 on the host.
No web server running on the host will be able to proxy PHP to it on port 9000 whatsoever.
The presence of an exposed port 80 here implies that there is a web server running inside this container.
The Docker hub page for this container also references Caddy, as well as the fact that it’s based on PHP-FPM:
This image is based on php:7.2-fpm official version.
:crown: Features
:lock: Automatic HTTPS (:heart: Caddy) :hammer: Fully production-ready through docker-compose :pencil: Adjustable to your needs via environment variable
—https://hub.docker.com/r/invoiceninja/invoiceninja
But I can’t find a Dockerfile, nor can I find anything explicit explaining the makeup of their app container. I went digging through their Github, but it was not very elucidating. At the moment, I’m still not sure what’s going on.
They seem to be shipping default web server configuration files in a ā€˜Dockerfiles’ repo (which has no Dockerfiles in it as far as I can see?): GitHub - invoiceninja/dockerfiles: Docker files for Invoice Ninja
In the repo there is a Caddyfile which uses app:9000 as its target:
And there is a docker-compose.yml which uses invoiceninja/invoiceninja:5 as an app service:
Although it doesn’t expose port 9000, the implication here is that invoiceninja/invoiceninja is a standard, port-9000-available PHP-FPM container, and you should consider exposing port 9000 to the host machine in order to proxy to it. Alternatively, put Caddy and this app together in the same Compose file and have Caddy refer to it over the Docker-Compose-created network.
I know none of this for sure, because the docs are not entirely clear, and I’m unable to test things myself at the moment.
I actually tried that since I do have php fpm on the host. I don’t remember what that error was but I do remember it didn’t work … which maybe means my container is … iffy? Lemme check that method again … stand by …
Here is the changed Caddyfile:
	root * /srv/public
	php_fastcgi unix//run/php/php8.1-fpm.sock {
		root /srv/public
and this produces no discernable error in either the docker container logs or caddy’s log and a blank screen.
So it’s not just me. :slight_smile: Thanks for confirming that I am not completely dense.
Yes I found that while they do mention Caddy, there is no example Caddyfile anywhere. I guess I could try the docker-compose and see if that makes a difference. I actually do expose :9000 (copied the wrong docker run command):
docker run -d \
  -e APP_DEBUG=0 \
  -p '8010:80' \
  -p '8011:9000' \
… and no dice.
Which makes me think that this should be a post on their forum not ā€œoursā€ :slight_smile:
BTW: I absolutely am in love with Caddy.
Caddy on the host machine is trying to proxy to the host machine’s FPM socket, not the FPM socket of the container you’re running.
I know this because your docker command does not have a volume (-v) flag relating to the socket, so the container cannot be bind mounting the socket.
Ahh!
So you’re actually exposing the container’s PHP-FPM listener on the host’s port 8011 (Docker published ports come in the format of hostport:containerport).
That means you can’t php_fastcgi localhost:9000, you need to php_fastcgi localhost:8011 from your Caddy server running on the host machine.
We stan a based webserver.
Yes. I apologize for the confusion. I tried exposing 9000:9000 and proxying to that and I tried exposing 8011:9000 and proxying to that … same thing. Blank page or ā€œFile not foundā€ and I know the index.php is in the same directory being accessed because I can browse to the robots.txt file in that directory.
And honestly, now that we are talking about it … I am beginning to believe the problem is with the container … not Caddy. So let me experiment some more with their installation documentation. Thanks for all your help and again sorry for the confusion.
Oh … in my search, I stumbled on this post but the Caddyfile is v1 and I am being lazy learning how to convert v1 to v2. :nerd_face:
I have to question, here… are you sure that’s the case?
In both the container and the host?
I note that you’ve translated the volume mount in your Docker run command:
So, while Caddy on your web server can see all the files in your web root… When it tells PHP-FPM to read the file in /srv/public/index.php, that file inside the container isn’t actually there; it’s in /var/www/app/public/index.php!
I think you might need to configure Caddy to tell your PHP-FPM container about this discrepancy.
Where you have root specified as a subdirective to php_fastcgi, instead, specify root /var/www/app/public (leaving the main Caddyfile web root as /srv/public).
Ooh … lemme try this… brb
ETA:
Progress… now I get a page but a 500 error!
ETAA:
Got it working! THANKS!!! (the 500 error was because my app key wasn’t correct, in case you were wondering…)
Caddy and the Caddy community rock socks! :nerd_face:
Nice! Glad to hear it!
