1. Caddy version:
2.6.12. How I installed, and run Caddy:
sudo snap install rocketchat-servera. System environment:
Ubunu 22.04
sudo systemctl restart snap.rocketchat-server.rocketchat-caddy
no
https://chat.pgem.ru:443
reverse_proxy localhost:3000
tls internal
Please write me, how I can write the request code to the configuration file: /var/snap/rocketchat-server/current/Caddyfile
to make the process work, my local path to get the certificate is: /var/www/letsencrypt/.
i need to open a folder for sharing /.well-known/acme-challenge/
thank you!
I don’t have enough knowledge, it gives such an error
pgem@chat:~$ sudo certbot certonly --webroot
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): chat.pgem.ru
Requesting a certificate for chat.pgem.ru
Input the webroot for chat.pgem.ru: (Enter 'c' to cancel): /var/www/letsencrypt
Certbot failed to authenticate some domains (authenticator: webroot). The Certificate Authority reported these problems:
Domain: chat.pgem.ru
Type: unauthorized
Detail: 89.17.41.34: Invalid response from https://chat.pgem.ru/.well-known/acme-challenge/UO87Fl5sgw_GpK772YHICOawg-DBAqilh1BUKrx7MO0: "<!DOCTYPE html>\n<html>\n<head>\n <link rel=\"stylesheet\" type=\"text/css\" class=\"__meteor-css__\" href=\"/ae2dbc3e8f9ef6251720fa82c0d"
Hint: The Certificate Authority failed to download the temporary challenge files created by Certbot. Ensure that the listed domains serve their content from the provided --webroot-path/-w and that files created there can be downloaded from the internet.
Some challenges have failed.
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.
