1. Output of caddy version
Debian 11 on WSL with systemd-genie installed (so, systemd works)
sudo systemctl start caddy
Type=notify
:63342 {
root * /srv/php
php_fastcgi unix//run/php/php8.1-fpm-testsite.sock
output file /var/log/testsite.log
I have a very simple
<?php
phpinfo();
Script located at /srv/php/test.php
. I’m trying to view its output (and thereby confirm that the web server is functioning correctly) via my PhpStorm editor’s preview functionality. It keeps attempting to use port 63342, which is why I modified my Caddyfile to listen to that port specifically.
I’m used to using NGINX in a multiple virtual host setup, so I created a testsite user and a separate PHP-FPM for it (located at /etc/php/8.1/fpm/pool.d/testsite.conf
[testsite]
user=testsite
group=testsite
listen=/var/run/php/php8.1-fpm-testsite.sock
listen.owner=www-data
listen.group=www-data
php_admin_value[disable_functions]=exec,passthru,shell_exec,system
php_admin_flag[allow_url_open]=off
pm=dynamic
pm.max_children=5
pm.start_servers=2
pm.min_spare_servers=1
pm.max_spare_servers=3
chdir=/
The /srv/php/test.php
file is owned by the testsite user
journalcltl -u caddy --no-pager | less +G
output:
ws/System32
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: INSIDE_GENIE=yes
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: WSL_DISTRO_NAME=Debian
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: WSL_INTEROP=/run/WSL/763_interop
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: WSLENV=
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: DISPLAY=:0
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: WAYLAND_DISPLAY=wayland-0
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: PULSE_SERVER=/mnt/wslg/PulseServer
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: NOTIFY_SOCKET=/run/systemd/notify
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: HOME=/var/lib/caddy
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: LOGNAME=caddy
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: USER=caddy
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: INVOCATION_ID=6c3445e0728d444b8ab686fc4e7864ef
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: JOURNAL_STREAM=7:23027
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: {"level":"info","ts":1661736371.5275252,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: {"level":"info","ts":1661736371.5290816,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["//[::1]:2019","//127.0.0.1:2019","//localhost:2019"]}
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: {"level":"info","ts":1661736371.5293207,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000156bd0"}
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: {"level":"info","ts":1661736371.5295382,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: {"level":"info","ts":1661736371.5295572,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: {"level":"info","ts":1661736371.529564,"logger":"tls","msg":"finished cleaning storage units"}
Aug 28 21:26:11 KEVIN-DESKTOP-wsl caddy[3612]: {"level":"info","ts":1661736371.5296655,"msg":"serving initial configuration"}
Aug 28 21:26:11 KEVIN-DESKTOP-wsl systemd[1]: Started Caddy.
No errors outside of a 502 Bad Gateway. Nothing logged at /var/log/testsite.log
Double-checked my FPM config setup with what works with my NGINX setups. Added the log directive to my Caddyfile in the hopes of getting some hint of what’s not working. Moved the test file out of my home directory. Changed the port in the Caddyfile to what PhpStorm is trying to use.
