Hi here,
Simple install on PI
bullseye/sid
caddy start and then a lot of caddy reload (as root user)
http://mikangye.lan {
root * /var/www/test/index.html
mikangye.lan {
respond hello-https
api.pellets.localhost {
log
tls internal
#php_fastcgi 127.0.0.1:9000
encode gzip zstd
First i’m new to web hosting.
I’m trying to host my webapp api (php api-platform) and my own front (react) on my PI with tls as i would have access with phone/table etc on local network.
I have always an “HTTP/1.1 308 Permanent Redirect”
All servname point to “192.168.1.43” (all declared in an SFR “box”). None are in /etc/hosts
on api.pellets.localhost: status 308
curl -v -k api.pellets.localhost
* Trying ::1:80...
* TCP_NODELAY set
* Connected to api.pellets.localhost (::1) port 80 (#0)
> GET / HTTP/1.1
> Host: api.pellets.localhost
> User-Agent: curl/7.68.0
< Connection: close
< Location: https://api.pellets.localhost/
< Server: Caddy
< Date: Wed, 09 Feb 2022 13:39:42 GMT
< Content-Length: 0
* Closing connection 0
on mikangye.lan: status 200 ok
root@ubuntu:/etc/caddy# curl -v mikangye.lan
* Trying 192.168.1.43:80...
* TCP_NODELAY set
* Connected to mikangye.lan (192.168.1.43) port 80 (#0)
> GET / HTTP/1.1
> Host: mikangye.lan
< HTTP/1.1 200 OK
< Server: Caddy
< Date: Wed, 09 Feb 2022 13:49:17 GMT
< Content-Length: 0
* Connection #0 to host mikangye.lan left intact
From caddy start:
2022/02/09 13:43:20.844 INFO using adjacent Caddyfile
2022/02/09 13:43:20.848 WARN input is not formatted with 'caddy fmt' {"adapter": "caddyfile", "file": "Caddyfile", "line": 12}
2022/02/09 13:43:20.852 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["localhost:2019", "[::1]:2019", "127.0.0.1:2019"]}
2022/02/09 13:43:20.853 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0x40002cc770"}
2022/02/09 13:43:20.853 WARN tls stapling OCSP {"error": "no OCSP stapling for [install]: no OCSP server specified in certificate"}
2022/02/09 13:43:20.853 DEBUG tls.cache added certificate to cache {"subjects": ["install"], "expiration": "2024/05/09 13:14:51.000", "managed": false, "issuer_key": "", "hash": "c919c676f99fc0220577b5cef51e9d87321b92251277fc3413f20cf054ab9eae", "cache_size": 1, "cache_capacity": 10000}
2022/02/09 13:43:20.853 INFO http server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server {"server_name": "srv1", "http_port": 80}
2022/02/09 13:43:20.854 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2022/02/09 13:43:20.856 INFO tls cleaning storage unit {"description": "FileStorage:/root/.local/share/caddy"}
2022/02/09 13:43:20.864 INFO tls finished cleaning storage units
2022/02/09 13:43:20.906 WARN pki.ca.local installing root certificate (you might be prompted for password) {"path": "storage:pki/authorities/local/root.crt"}
2022/02/09 13:43:20 define JAVA_HOME environment variable to use the Java trust
2022/02/09 13:43:20 not NSS security databases found
2022/02/09 13:43:22 certificate installed properly in linux trusts
2022/02/09 13:43:22.849 DEBUG http starting server loop {"address": "[::]:443", "http3": false, "tls": true}
2022/02/09 13:43:22.849 DEBUG http starting server loop {"address": "[::]:80", "http3": false, "tls": false}
2022/02/09 13:43:22.851 INFO http enabling automatic TLS certificate management {"domains": ["api.pellets.localhost"]}
2022/02/09 13:43:22.853 WARN tls stapling OCSP {"error": "no OCSP stapling for [api.pellets.localhost]: no OCSP server specified in certificate"}
2022/02/09 13:43:22.853 DEBUG tls.cache added certificate to cache {"subjects": ["api.pellets.localhost"], "expiration": "2022/02/10 00:41:01.000", "managed": true, "issuer_key": "local", "hash": "4037a3abc9e036a2900df7d76f9752c312347259b22921c51b9f0e8cb7b458f0", "cache_size": 2, "cache_capacity": 10000}
2022/02/09 13:43:22.854 INFO autosaved config (load with --resume flag) {"file": "/root/.config/caddy/autosave.json"}
2022/02/09 13:43:22.854 INFO serving initial configuration
Successfully started Caddy (pid=226276) - Caddy is running in the background
I’ve tried several things -_-
If i could have some help
