Help with layer4 & caddy2-ext/layer4 - Proxy both UDP and TCP
I’d like to utilize the layer4 app with caddy2-ext/layer4 to stick with the YAML Caddyfile, but be able to proxy UDP traffic to certain upstream servers.
Strech goal is to keep H3 running in the http app, so that certain upstream service can still be accessed via QUIC - so not all UDP requests should be covered by the Layer4 app, some still by http
It appears that I don’t quite get the concept or run into limitations of caddy2-ext/layer4. Is there a way to achieve my goal without going down the .json route?
In short, it should work like this:
----> Ingress 443
#Layer4
-------> vpn.domain.tld - proxied to wireguard:5820/udp
-------> turn.domain.tld - proxied to coturn:3389/udp & tls
-------> mumble.domain.tld - proxied to mumbleserver/udp & tls
#http with h1 h2 h3
-------> cloud.domain.tld - fast cgi to nextcloud:9000/udp&tcp & tls (this one would benefit from h3)
-------> mumble.domain.tld - proxied to mumblserver:/tcp & tls
-------> otherhttp.domain.tld - proxied to other_services:80/tcp & tls
In the caddyfile below the lines for layer4 are commented out. If I remove those comments and try to activate the, say, dot server, the error message below is shown:
"layer4 app module: start: listen udp 0.0.0.0:443: bind: address already in use"
Built my own caddy image:
FROM caddy:builder AS builder
RUN xcaddy build \
  --with github.com/greenpau/caddy-security \
  --with github.com/mholt/caddy-l4 \
  --with github.com/RussellLuo/caddy-ext/layer4
FROM caddy:latest
RUN apk add --no-cache nano
6.1.0-0.deb11.5-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.12-1~bpo11+1 (2023-03-05) x86_64 GNU/Linux
Debian Bullseye with backports for Bookworm Kernel
Docker run command
docker run -d \
	--restart always \
	-p 80:80 \
	-p 443:443 \
	-p 80:80/udp \
	-p 443:443/udp \
	--network=mynetwork \
	-v /home/user1/services/caddy/fs:/fs \
	-v /home/user1/services/caddy/data:/data \
	-v /home/user2/infra/caddy/Caddyfile:/etc/caddy/Caddyfile \
	-v /home/user1/services/caddy/config:/config \
        -v ~/webserver/nextcloud/pushsocket:/run/notify_push \
        -v nextcloud_install:/var/www/html:ro \
        -v storagebox_user1_crypt:/var/www/html/data/storagebox/user1:ro \
	-v storagebox_user3_crypt:/var/www/html/data/storagebox/user3:ro \
        -v ~/webserver/nextcloud/data:/var/www/html/data:ro \
        -v ~/webserver/nextcloud/apps:/var/www/html/custom_apps:ro \
	-v /home/user1/webserver/dl5gu.radio/hugo/output:/var/www/dl5gu.radio \
        -v /home/user1/webserver/productopia/hugo/output:/var/www/productopia \
	--name caddy \
	gymnae/caddy
	#https_port 443
	#default_bind 0.0.0.0
	#http_port 80
	servers tcp/0.0.0.0:443 {
		protocols h1 h2 h3
	#layer4 {
	#	udp/0.0.0.0:443 {
	#		turn.grundstil.de {
	#			tls
	#			proxy {
	#				to udp/signaling_coturn:3389
	#       vpn.grundsti.de {
	#	tls
	#	proxy {
	#		to udp/wireguard:51820
	#       dot.argonath.de, dot.grundstil.de, dot.amonsul.net, dot.wxbu.de {
	#	tls
	#	proxy {
	#		to udp/dnsproxy:853
	#       dot.amonsul.net {
	#	tls
	#	proxy {
	#		to dnsproxy:853
isso.dl5gu.radio, isso.productopia.net {
	reverse_proxy isso:8080
tube.wxbu.de {
	reverse_proxy invidious:3000
(matrix-well-known-header) {
	# Headers
	header Access-Control-Allow-Origin "*"
	header Access-Control-Allow-Methods "GET, POST, PUT, DELETE, OPTIONS"
	header Access-Control-Allow-Headers "Origin, X-Requested-With, Content-Type, Accept, Authorization"
	header Content-Type "application/json"
amonsul.net {
	handle /.well-known/matrix/server {
		import matrix-well-known-header
		respond `{"m.server":"matrix.amonsul.net:443"}`
	handle /.well-known/matrix/client {
		respond `{"m.homeserver":{"base_url":"https://matrix.amonsul.net"}}`
	respond "hello world"
grundstil.de, www.grundstil.de {
	root * /var/www/dl5gu.radio
		respond `{"m.server":"matrix.grundstil.de:443"}`
		respond `{"m.homeserver":{"base_url":"https://matrix.grundstil.de"}}`
	# Begin - Security
	# deny all direct access for these folders
	rewrite /(\.git|cache|bin|logs|backups|tests)/.* /403
	# deny running scripts inside core system folders
	rewrite /(system|vendor)/.*\.(txt|xml|md|html|yaml|yml|php|pl|py|cgi|twig|sh|bat)$ /403
	# deny running scripts inside user folder
	rewrite /user/.*\.(txt|md|yaml|yml|php|pl|py|cgi|twig|sh|bat)$ /403
	# deny access to specific files in the root folder
	rewrite /(LICENSE\.txt|composer\.lock|composer\.json|nginx\.conf|web\.config|htaccess\.txt|\.htaccess) /403
	respond /403 403
	## End - Security
	# global rewrite should come last.
	try_files {path} {path}/ /index.php?_url={uri}&{query}
argonath.de {
		respond `{"m.server":"matrix.argonath.de:443"}`
		respond `{"m.homeserver":{"base_url":"https://matrix.argonath.de"}}`
csgofastdl.amonsul.net {
	root * /fs/csgo
	# respond "hello world"
	file_server browse
csgo.wxbu.de {
	reverse_proxy csgo-webcron-server:8080
search:80, search.local:80, search.argonath.de, search.grundstil.de, search.amonsul.net {
	reverse_proxy searx:8080
pihole.amonsul.net, pihole.argonath.de, pihole.grundstil.de {
	reverse_proxy pi-hole:80
doh.wxbu.de, doh.productopia.net, doh.grundstil.de, doh.amonsul.net {
	reverse_proxy * amonsul-doh-server:8053
vpn.grundstil.de, vpn.amonsul.net {
	reverse_proxy wireguard:51820
mumble.wxbu.de, mumble.grundstil.de, mumble.wxbu.de, mumble.amonsul.net {
	reverse_proxy mumble-server:64738
space.wxbu.de, space.grundstil.de, space.amonsul.net {
	handle_path /radio/* {
		reverse_proxy botamusique_space:8181
	reverse_proxy gomumblesoundboard_space:3000
radio.wxbu.de {
freaks.grundstil.de, freaks.wxbu.de, freaks.amonsul.net {
	reverse_proxy gomumblesoundboard_freaks:3000
hw.wxbu.de, hw.grundstil.de, hw.amonsul.net {
	reverse_proxy gomumblesoundboard_hw:3000
http://cloud, cloud.wxbu.de, cloud.local, cloud.dl5gu.radio, cloud.argonath.de, cloud.productopia.net, cloud.grundstil.de, cloud.amonsul.net {
	redir /.well-known/webfinger /index.php/.well-known/webfinger 301
	redir /.well-known/nodeinfo /index.php/.well-known/nodeinfo 301
	handle_path /standalone-signaling/* {
		reverse_proxy signaling_spreed:8088
	route /push/* {
		uri strip_prefix /push
		reverse_proxy * unix//run/notify_push/notify_push.sock {
			trusted_proxies private_ranges
	@forbidden {
		path /.htaccess
		path /data/*
		path /config/*
		path /db_structure
		path /.xml
		path /README
		path /3rdparty/*
		path /lib/*
		path /templates/*
		path /occ
		path /console.php
	respond @forbidden 404
		root * /var/www/html
		php_fastcgi nextcloud:9000 {
			env front_controller_active true # Remove index.php form url
notify.amonsul.net, notify.grundstil.de {
mail.grundstil.de, mail.dl5gu.radio {
	respond "I am a mailserver"
turn.grundstil.de {
	reverse_proxy * signaling_coturn:3389 {
spreed.amonsul.net, spreed.grundstil.de {
	reverse_proxy dnsproxy:853
speedup.grundstil.de {
	reverse_proxy * docker-matomo-web-1:80
sftpgrav.grundstil.de {
	reverse_proxy * grundstil-grav-sftp:8080
calibre.grundstil.de {
	reverse_proxy * calibre-web:8083
backup.grundstil.de {
	reverse_proxy * kopia:51515
portainer.argonath.de, portainer.grundstil.de, portainer.productopia.net, portainer.amonsul.net {
	reverse_proxy * portainer:9000
matrix.wxbu.de, matrix.productopia.net, matrix.amonsul.net, matrix.grundstil.de, matrix.argonath.de {
	reverse_proxy /_matrix/* matrix-synapse-1:8008 {
	reverse_proxy /_synapse/client/* matrix-synapse-1:8008 {
element.amonsul.net, element.wxbu.de, element.productopia.net, element.grundstil.de, element.argonath.de {
	encode zstd gzip
	reverse_proxy matrix-element-1:80 {
monitor.grundstil.de, monitor.amonsul.net {
	reverse_proxy netdata:19999
	basicauth /* {
		<redacted> <redacted>
glances.wxbu.de {
	reverse_proxy glances:61208
	basicauth /* {
dl5gu.radio {
	#respond "und der seb darf mit in  mein raumschiff"
productopia.net, wxbu.de {
		respond `{"m.server":"matrix.productopia.net:443"}`
		respond `{"m.homeserver":{"base_url":"https://matrix.productopia.net"}}`
	#basicauth {
	#	<redacted> <redacted>
	#	root * /var/www/productopia
	redir https://cloud.wxbu.de/apps/collectives/wxbu.de permanent
	#	file_server
git.dl5gu.radio {
	reverse_proxy gitea:3000
drone.dl5gu.radio {
	reverse_proxy drone:80
rxresu.grundstil.de {
	handle_path /api/* {
		reverse_proxy rxresu_server:3100
	handle /* {
		reverse_proxy rxresu_client:3000
headscale.grundstil.de, headscale.productopia.net {
	reverse_proxy headscale:8080
mc.amonsul.net {
	reverse_proxy mc:8100
# Dashboard
https://dashboard.productopia.net {
	# Apply basic security headers
		# Enable cross origin access to *.productopia.net
		Access-Control-Allow-Origin *.productopia.net
		# Enable HTTP Strict Transport Security (HSTS)
		# Disallow the site to be rendered within a frame on a foreign domain (clickjacking protection)
		X-Frame-Options "SAMEORIGIN"
		# Prevent search engines from indexing
		X-Robots-Tag "none"
		# Remove the server name
		-Server
	reverse_proxy http://netmaker-ui
# API
https://api.productopia.net {
	reverse_proxy http://netmaker:8081
# mq
wss://broker.productopia.net {
	reverse_proxy ws://mq:8883
office.productopia.net, office.grundstil.de {
	reverse_proxy http://collabora:9980
reddit.wxbu.de, reddit.grundstil.de, reddit.productopia.net {
	reverse_proxy libreddit:8080
Btw, I wanted to say that for a looong time now: Caddy is an absolute blast to use and made my life soooo much easier. Thank you.
Caddyfile isn’t YAML, so I’m not sure what you mean there.
This doesn’t really make sense – h3 is UDP only. The default is already to enable all protocols, so this doesn’t do anything useful. Plus it probably doesn’t match any listeners because you don’t have any that match that exactly.
wss:// is not a valid scheme in Caddy. Neither is ws:// for upstream addresses. Remove both of those schemes, they don’t do anything.
The scheme is just a shortcut in browsers, it’s not really a real thing.
Remove the /*, this is very slightly less efficient. Having no matcher is faster because it doesn’t need to do a string comparison.
Remove the braces if you’re not setting any proxy options. Just cosmetic though.
You can remove the * for these as well, this is also just cosmetic.
Keep in mind you aren’t actually handling requests for other paths, so Caddy will just respond with an empty body. Probably best if you put something so it’s less confusing.
You can set this in global options now, which is what we recommend, so it’s set for all proxies at once:
	servers {
		trusted_proxies static private_ranges
This doesn’t work – Caddy’s path matcher is not a regexp matcher. If you want a regexp match, you need to use the path_regexp matcher (named matcher).
@deny-direct path_regexp /(\.git|cache|bin|logs|backups|tests)/.*
rewrite @deny-direct /403
Yeah, that’s impossible. You can’t have two servers listening to the same port.
The HTTP app wants to own ports 80 and 443 for a variety of reasons. You could use layer4 for other ports, but not those.
Thank you for taking the time to check my Caddyfile - I thought it was YAML, but something learned :slight_smile:
Is there a way to use port 443 for TCP/UDP at the same time with Caddy?
You already are – HTTP 1 & 2 use TCP and HTTP 3 uses UDP.
Ok, sorry to rephrase my question.
Can I achieve my stated goal? Or would it be easier if I turn off h3?
----> Ingress 443
#Layer4
#http with h1 h2 h3
Why can’t you use a different port for your non-HTTP UDP traffic?
Fewer ports I need to open in my firewall and a sure fire way through firewalls, where only few ports like 443/80 are open.
You’re making it more complicated than it needs to be. Just use a different port. That’s the reason ports exist, to differentiate different types of traffic.
If you used the same port, you’d still need to match on something in the traffic to route it to the correct place.
With HTTP you have headers like the Host header, with HTTPS you have TLS-SNI (server name identification).
You need some mechanism in to determine the kind of traffic (by looking at the shape of the bytes in the traffic) and something in the data to identify where it should go.
If you can’t do that because you don’t know exactly what the data is, or caddy-l4 doesn’t have specific support for that kind of data, then it’s not possible to route it.
So the only thing you can do is use a different port, because that clearly separates the traffic away from the rest, so the server doesn’t get confused.
I think my scenario is quite close to what this user here asked, but solved with layer4 & caddy-yaml:
I know which subdomains bring which traffic, could that be enough to route?
Example:
vpn.domain.tld → always UDP wireguard
turn.domain.tld → can be TCP and UDP, but UDP preferred
mumble.domain.tld → main traffic is udp
For now I’m able to use port 8080 for turn, which already enables me passing by some firewalls.
No, it’s not. You need to also know how to find that information from the traffic data coming in. If it’s a protocol Caddy doesn’t understand, then there’s no way to do that. Like I said, for HTTP you can use the Host header to find out the hostname the client requested, and for HTTPS you can use TLS-SNI. For wireguard… :man_shrugging:
Thank you @francislavoie, for clarifying this for me.
I guess then I will bypass caddy for my coturn and wireguard traffic
