I’m building a public facing API with two environments (production and testing/staging) which will utilise API-Keys for authentication, I’d like to make it such that I have two instances for both env, and a single API base URL (say api.example.com
Is it possible to achieve this using Caddy, that is, forward request base on a given header value, say, "api-key"
, if it starts with "api_test_theKeys"
it send the requests to to the test server/instance, and if it were to start with "api_live_theKeys"
it send the requests to to the production/live server/instance.
Mind you, I’ve done something similar with different base URLs for both environments (say api.example.com
for live, and api.test.example.com
for testing env), in this case the client’s demand I have it this way, and I’ve been looking at ways to go about it.
The client current infras are hosted on DigitalOcean, it occurred to me to put both instances (Droplets on DO) behind a load balancer, and set a listening rule to watch for the header key-value and forward requests accordingly to the droplets, unfortunately, DO only have forwarding rules.
Pardon my many NA
below, I’m not having issues with Caddy, I’ve used it a couple of times in the past, I just need advice, suggestions, pointers, and/or input to assist me here.
NA
v2.6.4
sudo apt install -y debian-keyring debian-archive-keyring apt-transport-https
sudo apt update
sudo apt install caddy
Ubuntu 22.04.2 LTS (GNU/Linux 5.15.0-67-generic x86_64) - On DigitalOcean
NA
NA
# domain name.
api.example.com {
# root * /var/www/html
reverse_proxy localhost:3000
# php_fastcgi localhost:9000
