After updating to caddy version 2.7.6 I am now getting “NET::ERR_CERT_AUTHORITY_INVALID” errors when i try to navigate to my proxied pages. I run my own step-ca as a root crt issuer. I don’t think the step-ca is the problem as caddy is still able to auto renew certs and my update logs show that a little while after I updated caddy, my services started not working correctly due to crt errors. The chain of trust I had working was Root CA → Caddy crt → server crt (that caddy generated). I would then trust the Root CA and the chain is fully trusted.
ERROR MESSAGE:
Subject:
Issuer: Caddy Local Authority - ECC Intermediate
Expires on: Dec 11, 2023
Current date: Dec 10, 2023
PEM encoded chain:
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----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using curl to hit one of my pages:
curl: (60) SSL certificate problem: unable to get local issuer certificate
how to fix it, please visit the web page mentioned above.
Cert being hosted by the root CA:
Common Name (CN) Step Online CA
Organization (O) <Not Part Of Certificate>
Organizational Unit (OU) <Not Part Of Certificate>
Common Name (CN) Bastion Yubikey
Organization (O) adminH
v2.7.6
debian 12, x86, in docker container
N/A, runninnig in docker
version: "3.9"
image: caddy:latest
- 443:443
- "443:443/udp"
- caddy-network
- caddy_data:/data
- caddy_config:/config
- /data/caddyfile/Caddyfile:/etc/caddy/Caddyfile:ro
- /usr/local/share/ca-certificates/bastion.crt:/etc/ssl/certs/bastion.crt:ro
logging:
driver: "json-file"
options:
max-size: "50m"
caddy-network:
external: true
caddy_data:
caddy_config:
#Global options
#Our local ACME server
acme_ca https://tinyca.home.arpa/acme/acme/directory
#A single server which will get a TLS certificate automatically
truenas.home.arpa {
reverse_proxy 192.168.9.6
proxmox.home.arpa {
reverse_proxy 192.168.9.5:8006 {
tls
tls_insecure_skip_verify
unifi.home.arpa {
reverse_proxy 192.168.9.2:8443 {
tls
gitea.home.arpa {
reverse_proxy gitea:3000
speedtest.home.arpa {
reverse_proxy speedtest
documentserver.home.arpa {
reverse_proxy documentserver
nextcloud.home.arpa {
header Strict-Transport-Security max-age=31536000;
reverse_proxy nextcloud:443 {
backup.home.arpa {
reverse_proxy urbackup:55414
backup-service.home.arpa
reverse_proxy urbackup:55415
grafana.home.arpa {
reverse_proxy grafana:3000
prometheus.home.arpa {
basicauth {
box password_here
reverse_proxy prometheus:9090
ansible.home.arpa {
reverse_proxy ansiblesemaphore:3000
kuma.home.arpa {
reverse_proxy uptimekuma:3001
opnsense.home.arpa {
reverse_proxy https://192.168.9.1 {
tls
pi-hole.home.arpa {
encode zstd gzip
redir / /admin{uri}
homeassistant.home.arpa {
reverse_proxy 192.168.9.97:8123
wazuh.home.arpa {
reverse_proxy wazuh.dashboard:5601 {
tls
dashy.home.arpa {
reverse_proxy dashy:80
portainer.home.arpa {
reverse_proxy portainer:9443 {
tls
pbs.home.arpa {
reverse_proxy 192.168.9.8:8007 {
tls
ntfy.home.arpa {
reverse_proxy ntfy:80
