Hi guys! I’m trying to deploy a dockerized react app using Caddy. Everything seems to be working fine, the https certificate is generated, and the index of the page is accessible:
curl -v https://new.ordename.cl/
But if I try to go to any other link on the page, I get a 404 Not Found error:
curl -v https://new.ordename.cl/products
I’ve tried different configurations in the Caddyfile but nothing seems to work.
What am I doing wrong? Any help would be really appreciated!
Which version, exactly? That’s just the docker tag you used to pull the image, but we need to know which version of Caddy you have pulled down.
You can find it by running caddy version inside the container.
If you use the caddy file-server command, then Caddy won’t use your Caddyfile at all.
Also, the default command in the official Caddy docker image uses /etc/caddy/Caddyfile as the path to the file. You’re copying your Caddyfile to the wrong location if you were to use the default command.
You’re using Caddy a v1 config here. You’ll need to rewrite your config with Caddy v2 syntax.
This is because you’re using caddy file-server which doesn’t do any special rewrites for you at all. So requests to /products is literally looking for a file or directory on disc at /usr/share/caddy/html/products, but it doesn’t find that.
Hi Francis! Thanks for such a detailed answer. I did’t know I had so many things wrong with my configuration. Answering your comments:
I decided to pull an image with a specific version, so now I’m doing:
FROM caddy:2.4.6-alpine
I suspected this, but I couldn’t confirm it since I didn’t find many information about this command and almost no examples online. Thanks for clarifying this!
Fixed!
COPY caddy/Caddyfile /etc/caddy/Caddyfile
I had no idea my config was outdated. What do you think know about it?
This is because you’re using caddy file-server which doesn’t do any special rewrites for you at all. So requests to /products is literally looking for a file or directory on disc at /usr/share/caddy/html/products , but it doesn’t find that.
Understood. Correct me if I’m wrong but now, with the proper Caddyfile config, I now should start caddy with “run” and it will use the config and start my server correctly?
