Help with Caddyfile
I’m trying to have a multiple file webserver and to have a path /api/* be a reverse proxy to a http (not https) backend webserver
I don't have an error I just don't know how to do this.
sudo apt-get install caddy
Lunix Ubuntu
site.raidxmc.org {
  root * /root/site/RaidXSite
  handle_path /api/* {
		reverse_proxy http://82.23.170.99:25569
  try_files {path} /index.html
none
Take a look at the docs for Directive Order.
If you’re clear on the difference between
and
  handle /api/* {
you probably want something like this:
site.raidxmc.org {
  redir /api /api/
