Help with Caddy Reverse Proxy Path Issue for WordPress Dashboard Under Subdirectory
I’m trying to access my WordPress dashboard at https://finitetouchstudio.com/frankenwp/wp-admin/ through a reverse proxy configuration with Caddy. When I log into the dashboard, the path changes to https://finitetouchstudio.com/wp-admin/ instead of staying under /frankenwp. Attempting to access anything from https://finitetouchstudio.com/wp-admin/ results in a 404 error, as my main site (hosted with Ghost) is on https://finitetouchstudio.com/. I need help ensuring that WordPress stays under the /frankenwp path so I can access and use my dashboard without redirection issues. -
[No specific error message, but accessing `https://finitetouchstudio.com/wp-admin/` results in a 404 error.]
v2.8.4 h1
/1nl4V4bxBrYoSoab7rL9BMYNk=
Installed Caddy from Caddy Repository via apt
OS: Ubuntu in digital ocean droplet
Relevant services: Caddy, Docker
Reverse proxy services for FrankenWP, phpMyAdmin, Ghost, Portainer, Rocket.Chat, and Jitsi Meet.
sudo apt install -y debian-keyring debian-archive-keyring apt-transport-https
sudo apt update
sudo apt install caddy -y
    email admin@finitetouchstudio.com
    acme_ca https://acme.zerossl.com/v2/DV90
finitetouchstudio.com {
     # FrankenWP Stack
    handle_path /frankenwp* {
        # Reverse proxy WordPress container running at localhost:8100
        reverse_proxy localhost:8100 {
    # phpMyAdmin under FrankenWP
    handle_path /frankenwp/phpmyadmin/* {
        reverse_proxy localhost:8086 {
    # Ghost Blog
    reverse_proxy localhost:2368
    # Portainer
    handle_path /portainer/* {
        reverse_proxy localhost:9000
    # Rocket.Chat
    handle_path /rocketchat/* {
        reverse_proxy localhost:8500
    # Jitsi Meet
    handle_path /jitsi/* {
        reverse_proxy localhost:8600
    # Enable HTTPS with ZeroSSL certificate
Howdy @Labib, welcome to the Caddy community.
This sounds like The "subfolder problem", OR, "why can't I reverse proxy my app into a subfolder?"
Specifically, it sounds like you don’t have the WordPress Address and/or the Site Address set correctly in your WordPress settings, and as a result it’s redirecting you incorrectly.
Remove this stuff from your config. It’s not necessary, Caddy already sets this correctly automatically. See reverse_proxy (Caddyfile directive) — Caddy Documentation
Keep in mind that Caddy sorts directives by the directive order. So your config happens to work because reverse_proxy comes after header in the directive order. But I’d recommend wrapping this in a handle so you have a proper fallback handling chain.
But as @Whitestrake said, you should consider using subdomains for each app, not subpaths. Subpath proxying is problematic for apps that don’t support “base path” config.
