I’m trying to migrate my PHP based (fastcgi via php7-fpm) nginx conf to caddy. Basically, the site is up and running, but the CSS file is not yet included.
Contents of the included snippets/fastcgi-php.conf (which came with nginx):
# regex to split $uri to $fastcgi_script_name and $fastcgi_path
fastcgi_split_path_info ^(.+?\.php)(/.*)$;
# Check that the PHP script exists before passing it
try_files $fastcgi_script_name =404;
# Bypass the fact that try_files resets $fastcgi_path_info
# see: http://trac.nginx.org/nginx/ticket/321
set $path_info $fastcgi_path_info;
fastcgi_param PATH_INFO $path_info;
fastcgi_index index.php;
include fastcgi.conf;
By now, I have the following Caddyfile:
www.mysite.de {
root /var/www/wikindx
log /var/log/caddy/access.log {
rotate_size 50 # Rotate after 50 MB
rotate_age 90 # Keep rotated files for 90 days
rotate_keep 20 # Keep at most 20 log files
rotate_compress # Compress rotated log files in gzip format
errors /var/log/caddy/error.log {
rotate_size 50
rotate_age 90
rotate_keep 20
rotate_compress
gzip
fastcgi / /run/php/php7.0-fpm.sock php
With that I get the basic HTML file, but without CSS. The CSS file is located in a subdirectory of the root file directory. How can I get the CSS file included?
Your nginx configuration doesn’t do any special handling for CSS. How did your site serve its CSS previously?
Ideally, the link tags in your HTML documents should point to the right subdirectory. If that can’t be done, you can look into rewriting CSS requests to the right place:
Hmm, not much of a HTML or CSS wizard here. My site is serving a bibliographic database running on WIKINDX (hence the template paths). The site runs flawlessly with those nginx code bits I showed out of the box. In the HTML header, I have
I looked at the Chrome DevTools output, and there are several files in subdirectories which get a 404 with my Caddy conf:
GET https://<mysite>/templates/simpleBlue/template.css net::ERR_ABORTED 404
GET https://<mysite>/core/javascript/coreJavascript.js net::ERR_ABORTED 404
GET https://<mysite>/core/ajax/json2.js net::ERR_ABORTED 404
GET https://<mysite>/templates/simpleBlue/template.js net::ERR_ABORTED 404
GET https://<mysite>/plugins/chooseLanguage/chooseLanguage.js net::ERR_ABORTED 404
GET https://<mysite>/templates/simpleBlue/images/wikindx-logo-anim.gif 404
GET https://<mysite>/templates/simpleBlue/icons/rss.png 404
This last one is really weird because there are several PNG files in the same directory (/var/www/wikindx/templates/simpleBlue/icons) which have no problems … Any clues how to rewrite or redirect these files?
