Help : Websocket question
Hi,
I’m using sveltekit and vite and caddyv2, love caddy!
But I’m having problem proxying websocket, so the condition is like this :
  • sveltekit with vite → npm run dev → it listens to localhost:3000, there’s hmr that using websocket
  • then I’m using https:\example.com to proxy to localhost, and here’s my caddy.json
  "apps": {
    "http": {
      "servers": {
        "srv0": {
          "listen": [
            ":443"
          "routes": [
              "match": [
                  "host": [
                    "example.com"
              "handle": [
                  "handler": "subroute",
                  "routes": [
                      "handle": [
                          "handler": "reverse_proxy",
                          "upstreams": [
                              "dial": "localhost:4000"
                      "match": [
                          "header": {
                            "Connection": [
                              "*Upgrade*"
                            "Upgrade": [
                              "websocket"
                      "handle": [
                          "upstreams": [
                              "dial": "localhost:3000"
As we can see above, I already use upgrade for websocket, that forward to localhost:4000
here’s vite config
vite: {
		server: {
                hmr: {
                    protocol: 'wss',
					port:4000
But it seems websocket is not proxied to hmr server, when I look @chrome dev tools, it always display pending
What did I do wrong ?
Thanks Websocket question
Edit: Using preformatted text Help : Websocket question
Next time, please fill out the help template. Why did you delete it? :frowning:
One thing I noticed: wss is websockets over HTTPS. Your proxy isn’t configured to use HTTPS. (Edit: It has been pointed out to me that wss refers to a client-side configuration, and so that’s probably fine.)
Web Sockets will always show as pending in dev tools because it never completes the request. It’s a live full-duplex protocol.
In other words, it sounds like it’s working.
Edit: you can check the network tab under dev tools to see the TCP frames actually being sent and received.
