Help! unrecognized servers option 'trusted_proxies'
here is my config
	servers {
		trusted_proxies static private_ranges
    root * /srv
    try_files {path} /index.html
here is my docker config:
FROM caddy:2-builder AS builder
RUN xcaddy build \
    --with github.com/mholt/caddy-ratelimit
FROM caddy:2-alpine
so when i run this config i get this error:
run: adapting config using caddyfile: parsing caddyfile tokens for ‘servers’: /etc/caddy/Caddyfile:5 - Error during parsing: unrecognized servers option ‘trusted_proxies’
What version of Caddy are you using? Make sure you build the latest version, v2.8.4.
Thanks, @francislavoie for the reply.
But it was my mistake.
i was using this FROM caddy:2.4.5-alpine as prod in my frontend docker file
but it should be like this FROM caddy:2-alpine as prod
