No problem really, just need help understanding the errors I’m seeing in my log files.
caddy | {"level":"info","ts":1697837817.767656,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy | {"level":"warn","ts":1697837817.7705762,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
caddy | {"level":"info","ts":1697837817.7803497,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
caddy | {"level":"info","ts":1697837817.7811875,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00035ff80"}
caddy | {"level":"info","ts":1697837817.7812967,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
caddy | {"level":"info","ts":1697837817.7813187,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
caddy | {"level":"info","ts":1697837817.7865067,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
caddy | {"level":"info","ts":1697837817.7869754,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
caddy | {"level":"info","ts":1697837817.7895164,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
caddy | {"level":"info","ts":1697837817.7896059,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
caddy | {"level":"info","ts":1697837817.7896128,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["dnd.longpants.ca","request.longpants.ca"]}
caddy | {"level":"info","ts":1697837817.8000422,"logger":"tls","msg":"finished cleaning storage units"}
caddy | {"level":"info","ts":1697837817.8035674,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
caddy | {"level":"info","ts":1697837817.8035948,"msg":"serving initial configuration"}
caddy | {"level":"error","ts":1697837822.3766484,"logger":"http.log.error","msg":"dial tcp 192.168.1.101:30000: connect: connection refused","request":{"remote_ip":"216.245.221.92","remote_port":"38194","client_ip":"216.245.221.92","proto":"HTTP/1.1","method":"GET","host":"dnd.longpants.ca","uri":"/","headers":{"Cache-Control":["no-cache"],"Referer":["https://dnd.longpants.ca"],"Accept-Encoding":[""],"User-Agent":["Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.uptimerobot.com/)"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"],"Accept-Language":["en-US,en;q=0.8"],"Connection":["close"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","server_name":"dnd.longpants.ca"}},"duration":0.000564683,"status":502,"err_id":"qk09quiiz","err_trace":"reverseproxy.statusError (reverseproxy.go:1265)"}
caddy | {"level":"error","ts":1697837828.5615337,"logger":"http.log.error","msg":"read tcp 172.23.0.2:57534->192.168.1.101:5055: read: connection reset by peer","request":{"remote_ip":"192.168.1.1","remote_port":"42750","client_ip":"192.168.1.1","proto":"HTTP/1.1","method":"GET","host":"request.longpants.ca","uri":"/","headers":{"Connection":["close"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"User-Agent":["Uptime-Kuma/1.23.3"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","server_name":"request.longpants.ca"}},"duration":0.000752057,"status":502,"err_id":"m8w2233bu","err_trace":"reverseproxy.statusError (reverseproxy.go:1265)"}
caddy | {"level":"error","ts":1697877486.3307326,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","upstream":"192.168.1.101:30000","duration":0.007199816,"request":{"remote_ip":"36.99.136.129","remote_port":"47347","client_ip":"36.99.136.129","proto":"HTTP/1.1","method":"GET","host":"dnd.longpants.ca","uri":"/scripts/prosemirror.js","headers":{"Referer":["https://dnd.longpants.ca/join"],"Accept-Encoding":["gzip"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 11_0_0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36"],"Accept":["*/*"],"X-Forwarded-For":["36.99.136.129"],"X-Forwarded-Proto":["https"],"Accept-Language":["en"],"Cookie":[],"X-Forwarded-Host":["dnd.longpants.ca"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","server_name":"dnd.longpants.ca"}},"error":"writing: write tcp 172.23.0.2:443->36.99.136.129:47347: write: broken pipe"}
caddy | {"level":"error","ts":1697877486.3740113,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","upstream":"192.168.1.101:30000","duration":0.027851921,"request":{"remote_ip":"36.99.136.129","remote_port":"47345","client_ip":"36.99.136.129","proto":"HTTP/1.1","method":"GET","host":"dnd.longpants.ca","uri":"/scripts/commons.js","headers":{"Cookie":[],"Accept-Encoding":["gzip"],"X-Forwarded-Host":["dnd.longpants.ca"],"Accept-Language":["en"],"Referer":["https://dnd.longpants.ca/join"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 11_0_0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36"],"X-Forwarded-For":["36.99.136.129"],"X-Forwarded-Proto":["https"],"Accept":["*/*"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","server_name":"dnd.longpants.ca"}},"error":"writing: write tcp 172.23.0.2:443->36.99.136.129:47345: write: connection reset by peer"}
caddy | {"level":"error","ts":1697877486.380231,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","upstream":"192.168.1.101:30000","duration":0.010220778,"request":{"remote_ip":"36.99.136.129","remote_port":"47348","client_ip":"36.99.136.129","proto":"HTTP/1.1","method":"GET","host":"dnd.longpants.ca","uri":"/scripts/foundry.js","headers":{"Accept-Language":["en"],"X-Forwarded-For":["36.99.136.129"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["dnd.longpants.ca"],"Accept-Encoding":["gzip"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 11_0_0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36"],"Accept":["*/*"],"Cookie":[],"Referer":["https://dnd.longpants.ca/join"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","server_name":"dnd.longpants.ca"}},"error":"writing: write tcp 172.23.0.2:443->36.99.136.129:47348: write: broken pipe"}
caddy | {"level":"error","ts":1697877486.418957,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","upstream":"192.168.1.101:30000","duration":0.010701425,"request":{"remote_ip":"36.99.136.128","remote_port":"59315","client_ip":"36.99.136.128","proto":"HTTP/1.1","method":"GET","host":"dnd.longpants.ca","uri":"/scripts/pixi.min.js","headers":{"Accept-Language":["en"],"Referer":["https://dnd.longpants.ca/join"],"Accept-Encoding":["gzip"],"X-Forwarded-Proto":["https"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 11_0_0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36"],"Accept":["*/*"],"X-Forwarded-Host":["dnd.longpants.ca"],"Cookie":[],"X-Forwarded-For":["36.99.136.128"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","server_name":"dnd.longpants.ca"}},"error":"writing: write tcp 172.23.0.2:443->36.99.136.128:59315: write: broken pipe"}
Using docker compose, and this official container: Docker
Ubuntu 22.04.3 LTS (GNU/Linux 5.15.0-87-generic x86_64)
sudo docker compose up -d
image: caddy:latest
cap_add:
- NET_ADMIN
- "443:443/udp"
- /home/plexmini/docker/caddy/Caddyfile:/etc/caddy/Caddyfile
- /home/plexmini/docker/caddy/caddy_data:/data
- /home/plexmini/docker/caddy/caddy_config:/config
caddy_data:
external: true
caddy_config:
request.longpants.ca {
tls myemail@gmail.com
reverse_proxy 192.168.1.101:5055
dnd.longpants.ca {
reverse_proxy 192.168.1.101:30000
