Anonyy
(Anon Ymous)
1
Trying to reverse proxy to http://127.0.0.1:4000 while the uri is mydomain.com/radio/
When going to /radio the app redirects to /setup, the app is Azuracast
domain.com{
handle_path /radio* {
rewrite * /radio/{uri}
reverse_proxy http://127.0.0.1:4000
ARM64 binary from the official site
Chromebook with Linux Dev Enviroment(screen is broken so repourpusing it as a server)
./caddy start
Howdy @Anonyy, welcome to the Caddy community!
The error you’re facing is a logical problem, not a bug. It will need a bit of special attention to resolve.
I’ve written about it in the past - hopefully this helps you understand the issue and your options for correcting it.
