I got ntlm module added in caddy
But im wondering how I should setup the Caddyfile to route to this iis host with ntlm parameters.
Caddyfile:
wac.domain.com {
“handler”: “reverse_proxy”,
“transport”: {
“protocol”: “http_ntlm”,
“tls”: {
“insecure_skip_verify”: true
“upstreams”: [
{“dial”: “192.168.1.100:433”}
Is this gonna work?
Like I said on Github, you can’t mix JSON and Caddyfile syntax. Did you read the docs?
You’ll also need to download a build of Caddy with the ntlm plugin from Download Caddy or use xcaddy to build it
You didn’t fill out the help thread template, please do so.
And when posting code snippets, please use ``` on the lines before and after your config/logs to use code formatting.
hez2010
(Steve)
3
mvthul
(Mvthul)
5
windowsadmincenter.domain.com {
import tls
reverse_proxy {
transport http_ntlm {
tls_insecure_skip_verify
to $IPADDRESS:443
encode zstd gzip
output stdout
Found a solution! this well applies for nextcloud with:
nextcloud.domain.com {
import tls
reverse_proxy {
to $IPADDRESS:443
encode zstd gzip
output stdout
or json format:
"match": [
"host": [
"windowsadmincenter.domain.com"
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"encodings": {
"gzip": {},
"zstd": {}
"handler": "encode"
"handler": "reverse_proxy",
"transport": {
"protocol": "http_ntlm",
"tls": {
"insecure_skip_verify": true
"upstreams": [
"dial": "$IPADDRESS:443"
"terminal": true
mvthul
(Mvthul)
6
Now im fully migrated from nginx to caddy! Topic can be closed!
system
(system)
Closed
7
