monitoring.example.com/oauth2/* {
reverse_proxy 127.0.0.1:4180
monitoring.example.com {
respond "Hello world! (oauth2)"
# [...] snippet and subdomains definition, see full config below
This current version is deprecated according to caddy validate :
Path in a site address is deprecated; please use the 'handle' directive instead
but my understanding of the required change does not work :
handle_path /oauth2/* {
handle_path / {
This second version gets rid of the caddy validate
depreciation warning, but then subdomains do not re-direct correctly, e.g. alertmanager.monitoring.example.com
does not reroutes to alertmanager behind, and sticks to the oauth2-proxy
page.
when using the handle and handle_path, it seems to overwrite other routes, for example
alertmanager.monitoring.example.com or prometheus.monitoring.example.com
v2.10.0
Type=notify
# logs configuration
log main {
include http.log.access.main
roll_size 1gb
roll_keep 5
roll_keep_for 720h
log none {
include http.log.access.none
output discard
format console
# no auth, grafana handles oauth itself, refer to grafana config
grafana.monitoring.example.com {
log main
reverse_proxy 127.0.0.1:3000
#monitoring.example.com {
# handle_path /oauth2/* {
# reverse_proxy 127.0.0.1:4180
# handle_path / {
# respond "Hello world! (oauth2)"
(authenticated_site) {
log main
# Requests to /oauth2/* are proxied to oauth2-proxy without authentication.
# You can't use `reverse_proxy /oauth2/* oauth2-proxy.internal:4180` here
# because the reverse_proxy directive has lower precedence than the handle directive.
handle /oauth2/* {
reverse_proxy 127.0.0.1:4180 {
header_up X-Forwarded-Uri {uri}
forward_auth 127.0.0.1:4180 {
uri /oauth2/auth
# oauth2-proxy requires the X-Real-IP and X-Forwarded-{Proto,Host,Uri} headers.
# The forward_auth directive automatically sets the X-Forwarded-{For,Proto,Host,Method,Uri} headers.
# If needed, you can copy headers from the oauth2-proxy response to the request sent to the upstream.
# Make sure to configure the --set-xauthrequest flag to enable this feature.
copy_headers X-Auth-Request-User X-Auth-Request-Email
# If oauth2-proxy returns a 401 status, redirect the client to the sign-in page.
@error status 401
handle_response @error {
redir * /oauth2/sign_in?rd={scheme}://{host}{uri}
reverse_proxy {args[0]} {
header_up X-Forwarded-User {http.request.header.X-Auth-Request-User}
header_up X-Forwarded-Email {http.request.header.X-Auth-Request-Email}
header_up X-Forwarded-Groups {http.request.header.X-Auth-Request-Groups}
header_up Host {host}
header_up X-Forwarded-Method {method}
header_up X-Auth-Request-User {>X-Auth-Request-User}
header_up X-Auth-Request-Email {>X-Auth-Request-Email}
header_up X-Scheme {scheme}
header_up X-Auth-Request-Redirect {scheme}://{host}{uri}
# Public endpoint for oauth2-proxy itself
oauth.monitoring.example.com {
reverse_proxy localhost:4180
# Prometheus UI with OAuth2
prometheus.monitoring.example.com {
import authenticated_site http://127.0.0.1:9090
# Alertmanager UI with OAuth2
alertmanager.monitoring.example.com {
import authenticated_site http://127.0.0.1:9093
