I am trying to convert from Nginx to caddy, I have most of it but I am getting stuck on the rewrite.
rewrite "^(.*)/_images/([0-9a-f]{2})([0-9a-f]{2})([0-9a-f]{28}).*$" /$1/images/$2/$2$3$4 break; rewrite "^(.*)/_thumbs/([0-9a-f]{2})([0-9a-f]{2})([0-9a-f]{28}).*$" /$1/thumbs/$2/$2$3$4 break; rewrite "^(.*)/(.*)\.(php|css|js|gif|png|jpg|ico|html|manifest|appcache|txt|jar)$" /$1/$2.$3 break; rewrite "^(.*)/(.*)\?(.*)$ /$1/index.php?q=$2&$3" last; rewrite "^(.*)/(.*)$ /$1/index.php?q=$2" last; rewrite ^/(.*)$ /index.php?q=$1 last;
This is for Shimmie2.
Thanks.
That’s a lot of rewriting to do!
The general conversion of syntax when regex is involved is:
# nginx
rewrite $REGEX $DESTINATION $OTHER_STUFF;
# caddy
rewrite {
r $REGEX
to $DESTINATION
Where $1, $2, $3 etc. in nginx become {1}, {2}, {3} in Caddy.
https://caddyserver.com/docs/rewrite
That helps a lot thanks.
Now really quick about this line
rewrite “^(.)/_images/([0-9a-f]{2})([0-9a-f]{2})([0-9a-f]{28}).$” /$1/images/$2/$2$3$4 break;
what happens with .*$" on the end of the regex?
or even a bunch of the $ I see around on the ends of lines
$ is what’s called an anchor; specifically, the end anchor. It signifies the end of line. ^ is the beginning anchor (start of line).
.* means zero or more of any character.
In the context of web requests, they are effectively meaningless and cancel each other out - you could remove any instance of .*$ from your Caddyfile with no effect. In a multiline regex, this structure would match a line of any length, but only one line.
A really good reference and testing tool for regex can be found here: http://www.regexr.com/
