Help me with maxmind_geolocation please
When setting up maxmind_geolocation I can’t block non-IT IPs.
I can either block everyone (if I write error @geo 403 before the reverse_proxy instruction) or no one (if I don’t write error @geo 403, but i write reverse_proxy @geo jellyfin:8096)
I tried with my italian IP and with a VPN service (both US and european IPs)
docker logs caddy gives no errors at all
v2.11.1
docker compose
        admin off
        servers {
                client_ip_headers X-Forwarded-For
                trusted_proxies static private_ranges
                trusted_proxies_strict
        order crowdsec before respond
        crowdsec {
                api_url http://crowdsec:8080
                api_key "MYKEY"
                ticker_interval 15s
                appsec_url http://crowdsec:7422
                #disable_streaming
                #enable_hard_fails
                        roll_size 30MiB
                        roll_keep 5
(default-headers) {
                -frameDeny
                -sslRedirect
                -browserXssFilter
                -contentTypeNosniff
                -forceSTSHeader
                -stsIncludeSubdomains
                -stsPreload
                -stsSeconds 15552000
                -customFrameOptionsValue SAMEORIGIN
                -customRequestHeaders X-Forwarded-Proto https
*.test.mydomain.com {
                dns cloudflare MYKEY
                propagation_delay 2m
                resolvers 1.1.1.1
        log
        @geo maxmind_geolocation {
                db_path "/etc/caddy/GeoLite2-Country.mmdb"
                allow_countries IT
        @test host *
        @jellyfin host jellyfin.test.mydomain.com
        route @test {
                crowdsec
                appsec
                respond "test"
        route @jellyfin {
# I can reach jellyfin:8096 with my italian IP but I can do that even with a non-IT VPN
                error @geo 403
                crowdsec
                appsec
                reverse_proxy jellyfin:8096
# I already tried reverse_proxy @geo jellyfin:8096
I tried this too (this gives error 403 to everyone, IT and outside):
@geo {
                not maxmind_geolocation {
                        allow_countries IT
                not remote_ip 172.24.0.0/22 # My container's IPs
route @jellyfin {
                error @geo 403
                crowdsec
                appsec
You’d probably be best served by opening an issue on the plugin’s repo.
