ps2xu
                (Dijiang Xu)
                    June 26, 2019, 12:47am
              1
 Hey guys, I can’t verify after using the filter on my website, directly prompting 401 Unauthorizd, no dialog box.  And I don’t want to delete the verification, thank you.
https://www .*****.com {
root /usr/local/caddy/www
tls xxx@xxxxx.com
basicauth / 123 456
timeouts none
gzip
filter rule {
content_type text/.*
search_pattern xxxxx/images/
replacement xxxxx/gooimg/
              Hi @ps2xu , welcome to the Caddy community.
What version of Caddy are you using?
Can you give us the output of: curl -kIL https://www.*****.com
Can you then remove the filter directive and give us the output of the same command?
                ps2xu
                (Dijiang Xu)
                    June 27, 2019,  1:23am
              3
              Hey, thank you for your help.
-------------------with filter---------------------
HTTP/1.1 401 Unauthorized
Server: Caddy
X-Content-Type-Options: nosniff
Date: Thu, 27 Jun 2019 00:43:54 GMT
Content-Length: 17
-------------------------After remove the  filter--------------------
Server: Caddy
Www-Authenticate: Basic realm=“Restricted”
Date: Thu, 27 Jun 2019 01:21:20 GMT
Content-Length: 17
I just tested this with Caddy (v1.0.0 (h1:KI6RPGih2GFzWRPG8s9clKK28Ns4ZlVMKR/v7mxq6+c=)). This part goes missing when the filter directive is added, I’m not quite sure why. basicauth should execute after  filter in plugin order, and this header should be added by basicauth.
Could you please add a new issue here: Issues · caddyserver/caddy · GitHub
Fill out the issue template and include a link to this thread. It might be that the issue is with filter, in which case an issue will have to be opened at GitHub - echocat/caddy-filter: Provides a directive to filter response bodies in caddy.  instead, but we’ll figure that out.
                ps2xu
                (Dijiang Xu)
                    June 27, 2019,  4:52am
              5
              Thank you very much, I have opened an issue.
                system
                (system)
                  Closed
                    September 25, 2019,  4:53am
              6
