1. Caddy version (caddy version): 2.0
2. How I run Caddy: Runs on domain member Windows 10 host. Domain: rkirchhof.net
I have a local DNS zone for kirchhof.tech addresses. Kirchhof.tech url’s all resolve to my homes ISPs ip address. Ports 80 and 443 are forwarded to caddy2 server.
a. System environment: Windows 10 Caddy2 runs at startup (Post login)
Caddy.exe run --watch
paste full file contents here
fo76wdb.kirchhof.tech:443 {
reverse_proxy webserver.kirchhof.tech:2020
tv.kirchhof.tech:443 {
reverse_proxy hv1.kirchhof.tech:8096
mail.kirchhof.tech:443 {
reverse_proxy ME-1.rkirchhof.net:80
sonarr.kirchhof.tech:443 {
reverse_proxy hv1.kirchhof.tech:8989
sabnzbd.kirchhof.tech:443 {
reverse_proxy hv1.kirchhof.tech:8085
couchpotato.kirchhof.tech:443 {
reverse_proxy hv1.kirchhof.tech:5050
Using reverse proxy feature. All seems to work fine. I just need help understanding console errors
2020/06/23 16:00:48 http: TLS handshake error from 222.186.19.210:35068: tls: first record does not look like a TLS handshake
2020/06/23 16:07:06 http: TLS handshake error from 193.118.53.210:43792: no certificate available for ‘45.18.10.201’
2020/06/23 16:08:51 http: TLS handshake error from 142.112.145.68:54120: no certificate available for ‘kirchhof.tech’
2020/06/23 16:08:51 http: TLS handshake error from 142.112.145.68:54140: tls: client offered only unsupported versions: [301]
2020/06/23 16:08:51 http: TLS handshake error from 142.112.145.68:54154: tls: client offered only unsupported versions: []
2020/06/23 16:08:51 http: TLS handshake error from 142.112.145.68:54162: EOF
2020/06/23 16:08:51 http: TLS handshake error from 142.112.145.68:54170: no certificate available for ‘kirchhof.tech’
2020/06/23 16:08:52 http: TLS handshake error from 142.112.145.68:54193: tls: client offered only unsupported versions: [301]
2020/06/23 16:08:52 http: TLS handshake error from 142.112.145.68:54205: tls: client offered only unsupported versions: []
2020/06/23 16:08:52 http: TLS handshake error from 142.112.145.68:54217: EOF
2020/06/23 16:08:52 http: TLS handshake error from 142.112.145.68:54227: no certificate available for ‘kirchhof.tech’
2020/06/23 16:08:52 http: TLS handshake error from 142.112.145.68:54243: tls: client offered only unsupported versions: [301]
2020/06/23 16:08:52 http: TLS handshake error from 142.112.145.68:54257: tls: client offered only unsupported versions: []
2020/06/23 16:08:52 http: TLS handshake error from 142.112.145.68:54271: EOF
2020/06/23 16:15:32 http: TLS handshake error from 40.77.167.169:12983: no certificate available for ‘kirchhof.tech’
2020/06/23 16:15:32 http: TLS handshake error from 40.77.167.169:13106: tls: client offered only unsupported versions: [302 301]
2020/06/23 16:15:32 http: TLS handshake error from 40.77.167.169:13164: tls: client offered only unsupported versions: [301]
2020/06/23 16:15:32 http: TLS handshake error from 40.77.167.169:13236: EOF
2020/06/23 16:21:58 http: TLS handshake error from 114.119.162.16:61876: no certificate available for ‘kirchhof.tech’
2020/06/23 16:38:32 http: TLS handshake error from 66.249.72.55:63963: no certificate available for ‘rkirchhof.net’
2020/06/23 17:32:48 http: TLS handshake error from 195.54.160.135:33400: no certificate available for ‘192.168.1.75’
2020/06/23 17:41:32 http: TLS handshake error from 195.54.160.135:58446: no certificate available for ‘192.168.1.75’
2020/06/23 17:41:34 http: TLS handshake error from 195.54.160.135:44022: no certificate available for ‘192.168.1.75’
2020/06/23 17:48:22 http: TLS handshake error from 66.249.69.206:48953: no certificate available for ‘kirchhof.tech’
2020/06/23 17:52:28 http: TLS handshake error from 203.173.10.149:41699: EOF
2020/06/23 17:59:24 http: TLS handshake error from 195.54.160.135:50242: no certificate available for ‘192.168.1.75’
2020/06/23 18:03:56 http: TLS handshake error from 114.119.166.187:48986: no certificate available for ‘kirchhof.tech’
2020/06/23 18:08:33 http: TLS handshake error from 34.75.187.236:55551: no certificate available for ‘rkirchhof.net’
2020/06/23 18:08:33 http: TLS handshake error from 34.75.187.236:53503: no certificate available for ‘rkirchhof.net’
2020/06/23 19:19:07 http: TLS handshake error from 207.46.13.88:16083: no certificate available for ‘kirchhof.tech’
2020/06/23 19:19:07 http: TLS handshake error from 207.46.13.88:16215: tls: client offered only unsupported versions: [302 301]
2020/06/23 19:19:07 http: TLS handshake error from 207.46.13.88:16292: tls: client offered only unsupported versions: [301]
2020/06/23 19:19:08 http: TLS handshake error from 207.46.13.88:16381: EOF
2020/06/23 19:44:40 http: TLS handshake error from 114.119.164.238:33470: no certificate available for ‘kirchhof.tech’
2020/06/23 20:05:26 http: TLS handshake error from 37.59.56.107:61252: no certificate available for ‘45.18.10.201’
2020/06/23 20:05:26 http: TLS handshake error from 37.59.56.107:61515: no certificate available for ‘45.18.10.201’
2020/06/23 20:13:01 http: TLS handshake error from 171.67.70.88:37592: no certificate available for ‘192.168.1.75’
2020/06/23 20:20:41 http: TLS handshake error from 66.249.66.18:47476: no certificate available for ‘kirchhof.tech’
2020/06/23 20:20:41 http: TLS handshake error from 66.249.66.16:55280: no certificate available for ‘kirchhof.tech’
2020/06/23 20:22:18 http: TLS handshake error from 95.163.255.46:52023: no certificate available for ‘kirchhof.tech’
2020/06/23 20:22:20 http: TLS handshake error from 95.163.255.44:35856: no certificate available for ‘kirchhof.tech’
2020/06/23 20:25:10 http: TLS handshake error from 107.217.53.76:57530: EOF
2020/06/23 20:52:16 http: TLS handshake error from 171.67.70.81:34116: no certificate available for ‘192.168.1.75’
2020/06/23 21:07:22 http: TLS handshake error from 195.54.160.135:50544: no certificate available for ‘192.168.1.75’
2020/06/23 21:24:04 http: TLS handshake error from 114.119.160.63:61898: no certificate available for ‘kirchhof.tech’
2020/06/23 21:28:44 http: TLS handshake error from 192.241.215.65:49424: no certificate available for ‘45.18.10.201’
What is a TLS handshake error?
Are these attempted efforts to gain unintended access?
On my external DNS server I remove wildcard records. all kirchhof.tech url’s use FQDN i.e tv.kirchhof.tech and fo76wdb.kirchhof.tech . . . That about it. Thank you.
