I am trying to use logHappens together with Caddy. But the .htaccess
file has some RewriteRules in which I can’t seem to convert to rewrite
rules in the Caddyfile
The .htaccess
has the following content:
<IfModule mod_rewrite.c>
RewriteEngine on
RewriteRule ^$ webroot/ [L]
RewriteRule (.*) webroot/$1 [L]
</IfModule>
And I try to make this into a rewrite * /webroot/{uri}
but this fails.
I am just starting with Caddy, so any help is very much appreciated
2024/03/20 16:06:52.313 DEBUG http.handlers.rewrite rewrote request {"request": {"remote_ip": "84.26.105.192", "remote_port": "49627", "client_ip": "84.26.105.192", "proto": "HTTP/2.0", "method": "GET", "host": "logs.example.domain", "uri": "/", "headers": {"Accept-Language": ["en-GB,en;q=0.9"], "Sec-Fetch-Dest": ["document"], "Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"], "Sec-Fetch-Site": ["none"], "Cookie": [], "Accept-Encoding": ["gzip, deflate, br"], "Sec-Fetch-Mode": ["navigate"], "User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.2.1 Safari/605.1.15"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "server_name": "logs.example.domain"}}, "method": "GET", "uri": "/webroot//"}
2024/03/20 16:06:52.313 DEBUG http.handlers.file_server sanitized path join {"site_root": "/var/www/logHappens", "request_path": "/webroot//", "result": "/var/www/logHappens/webroot"}
2024/03/20 16:06:52.314 DEBUG http.handlers.file_server no index file in directory {"path": "/var/www/logHappens/webroot", "index_filenames": ["index.html", "index.txt"]}
2024/03/20 16:06:52.314 DEBUG http.log.error.log1 {id=pwn5upcf2} fileserver.(*FileServer).notFound (staticfiles.go:629): HTTP 404 {"request": {"remote_ip": "84.26.105.192", "remote_port": "49627", "client_ip": "84.26.105.192", "proto": "HTTP/2.0", "method": "GET", "host": "logs.example.domain", "uri": "/", "headers": {"Sec-Fetch-Site": ["none"], "Cookie": [], "Accept-Encoding": ["gzip, deflate, br"], "Sec-Fetch-Mode": ["navigate"], "User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.2.1 Safari/605.1.15"], "Accept-Language": ["en-GB,en;q=0.9"], "Sec-Fetch-Dest": ["document"], "Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "server_name": "logs.example.domain"}}, "duration": 0.000358374, "status": 404, "err_id": "pwn5upcf2", "err_trace": "fileserver.(*FileServer).notFound (staticfiles.go:629)"}
Through the website, followed the installation instructions for Debian, Ubuntu.
Ubuntu Focal, running Caddy as systemd unit
systemctl start caddy
# /lib/systemd/system/caddy.service
# caddy.service
# for your installation.
Type=notify
log default {
format console
output file /var/log/caddy/system.log
exclude http.log.access
servers {
metrics
(log) {
format console
output file /var/log/caddy/{args[0]}.access.log {
roll_size 100mb
roll_keep 7
roll_keep_for 720h
root * /var/www/sandbox
import log sandbox
logs.example.domain {
root * /var/www/logHappens
import log logs.example.domain
